NEW SHARE
RD AT35 5 digits USB 3.0 color LCD Voltmeter ammeter
[Delivered very quickly, packed in foam box. The devices themselves in separate plastic boxes. Both the voltmeter and the load are assembled very neatly, work perfectly. Made sure that the usb3 port of my computer does not hold the load well… Many thanks to the seller and the manufacturer! ] https://www.aliexpress.com/item/33022448123.html
NEW SHARE
RD TC66C Type-C voltmeter ammeter
[Excellent tester. All functions in one review do not describe. I advise you to look at the reviews on youtube. The device is neatly assembled. The protective film slightly departed when i disassembled it to look-it still needs to be removed. The device came in time, the seller communicates well, gave a voltmeter. ] https://www.aliexpress.com/item/32968303350.html
NEW SHARE
RD HD25 HD35 Electronic USB Load
[The workmanship is excellent. With usb load, you can quickly and efficiently check the charger or power bank, check the maximum output current with the output voltage check and immediately determine the power source. The load also allows you to determine which fast charging standard supports the charger or power bank. You can manually switch the checked device to the desired standard of fast charging. You can also check and evaluate what current is able to miss the charging cable. The presence of 3 different connectors allow you to check the micro usb cable, USB-C, usb extension cable. Excellent tester for checking chargers, power bank and cables. Also, the HD-25 can be used in amateur radio practice as a load to check the setting of power supplies, etc. Devices in the range of output voltages 4-20v and current no more than 4a. I recommend this seller. I personally made sure that the quality of the goods, packaging and delivery are excellent. ] https://www.aliexpress.com/item/32917594486.html
NEW SHARE
RD 100v/33v10A 7in1 OLED Multifunction Tester
[to St. Petersburg. 11 days.Happy. The price, quality, functionality is 5 x 5 x 5 *. It corresponds to the description. I apologize three times for my “short” review … (tired … take a word, I took measurements = everything suits me, I agree with everyone with positive (quality) reviews, purchase and use a quality product … In my case, the errors of V. are 0.5, A-0.8 = completely satisfied. To the Seller Thank you. Good luck. I recommend.] https://www.aliexpress.com/item/32570250500.html
NEW SHARE
RD DPS5020 Constant Voltage current DC- DC Step-down communication Power Supply buck Voltage converter LCD voltmeter 50V 20A
【Order received. The seller quickly sends the goods. Quickly answers the question. The converter works. Thank you seller. I wish you success in business.】
NEW SHARE
RD UM34C Type-C DC voltmeter ammeter
[Works just as expected. If you want to know how your devices charge or why they probably don’t this is a great tool. You can also export the graphs into an Excel file. The app crashes when you do but the data are exported fine.] https://www.aliexpress.com/item/32880908871.html
NEW SHARE
RD UM24C APP USB 2.0 LCD Display Voltmeter ammeter
[Packed perfectly. Wonderful device, support two languages, on both sides of the film, it is not scratch on the screen. The screen is very bright. It is convenient to check chargers, cables, and generally monitor how the device consumes energy-) the work of “sinezuba” did not check. The link can download the manual in two languages, + app for pc. On the device itself there are four buttons, for navigation/settings they are enough.] https://www.aliexpress.com/item/32845522857.html
NEW SHARE
RD DPS5005 DC Step-down Power Supply
[All super!!! Prosperity 20 days (rostov region) Track tracked. Packing is just not a punched hopper. Despite the miniature size of the module, it is very convenient to use it. Everything is thought out to the smallest detail. The control panel and display interface is understandable. Build quality is worthy of respect! For connection used a switching power supply 24 v 8,33a 200 w. Clear work, exact values. Irreplaceable suitable for checking leds. Responsible and sociable seller. I turned to him regarding the input current, as i have it more than 1,1 times. A few minutes later the answer came: “there is no limit for the input current.” Thank you very much to the seller. Good luck to everyone! ] https://www.aliexpress.com/item/1000004290003.html
NEW SHARE
RD DPS5015 DC Step-down Power Supply
[The product corresponds to the description, it arrived safely and within the term guaranteed by the seller. It is functional and I am very pleased with the beginning of this kit. I trust with the seller, for those who want to buy it.] https://www.aliexpress.com/item/32702714880.html
[Damn nice little tool! Very tiny in size but mighty in functionality. A bit overwhelming at first, but very useful to check chargers and cables. I love it! Very cool that you can flip the display orientation per iPhone App.]
NEW SHARE
RD AT35 5 digits USB 3.0 color LCD voltmeter ammeter
[The goods came on time. Everything is intact. Packed perfectly. Look for yourself. I will note especially: for each model there is a qr code with instructions. I’ll check in — i’ll write.] https://www.aliexpress.com/item/33022448123.html
content:
From the moment of payment 20 days. Tracking full to post office. Packed super securely, as always with this seller. Inside the foam box. Cardboard boxes with tester marking. Included instruction with pictures and plugs with wires. I recommend the seller, i order from him not the first time
NEW SHARE
[Cool tester! Works fine, now you can check all your powerbanks! Many thanks to the seller and the manufacturer!!! The seller is very sociable and friendly!!! I recommend!] https://www.aliexpress.com/item/32880908871.html
NEW SHARE
RD AT34 USB 3.0 color LCD voltmeter ammeter
[Working tester! The accuracy of the readings was not tested, but i do not need special accuracy. The hood, the case is a good topic-i often carry with me (there is another tester in a simpler way. There are no these buns). A decent instrument! I’m happy… Bye!] https://www.aliexpress.com/item/32897200670.html
NEW SHARE
RD DPS5020 DC- DC Step-down communication Power Supply
[The parcel reached the Moscow region in 22 days, it was packed in a foam plastic box, the seller put a “crocodiles” gift the board with the installed elements looks good, it comes on plastic racks with internal thread, the converter works properly, but I had to dig into the memory settings.] https://www.aliexpress.com/item/32821185351.html
