The There Are No Stupid Questions Thread
Reflector makes a huge difference. It’s crucial.
Thanks Jason, after all I find your clues very useful. If I need to do it by iterations - fine.
Anyway, maybe somebody has already gone through the problem I’m analyzing now. To be more substantial: I need 3 meters hotsport at a distance of 70meters. I’m aiming to use Convoy L2, but then I’m confused if I should go for:
- Samsung LH351D (very welcome due to hight CRI) / “” De-domed?
- XHP50.2 De-Domed (since I’d rather throw over spill)
- Luxeon V
- SST-40 De-domed (less preffered due to greens and CRI)
  • else?
Living in central Europe I don’t have that easy access to some less popular LEDs, so Arrows and other serious providers are out of my capability. Just common KD, BG, Ali, L4P, INTL… eventually MTN but very expensive and lenghty delivery.
Do you have the L2 or a light with similar sized reflector right now?
Keep in mind the Luxeon V, SST-40 and LH351D are all about the same die size, about 2mm x 2mm. No big difference there. Slicing the dome off will make the big difference. Xpl-hi is like a factory dedome and also 2mm x 2mm.
Then the 50.2 die is 3mm x 3mm. I would estimate the other 3 leds with dome on would make about the same hot spot size as the 50.2 with dome sliced off.
So all these leds and dome on or off will only give you roughly 3 different hot spot sizes.
Are you going to use the stock L2 driver or swap a new one?
User DTA has made many beam shot videos of lights at fixed distances. We can probably find the right led once we know the distances. I’m waiting on his response.
Here is his video of the Convoy L2 with the xhp50.2.
I don’t know the distances in the video, but maybe it gives you a good visual idea of this reflector/led combo.
Jason, once again thank you for involvement. Yes, I have the L2 right now. I’m thinking of L4P 20mm driver since the flashlight is supposed to have just one mode (light for machine gun fixed on the car roof).
The bad news is L4P driver is not buck, so hard to use 2x26650 which I would wish to. Only 6V led would allow to do it without any further adjustments.
Such deep thinking going on! Thought I’d “lighten” the subject a bit.
My idea of a good companion for my D4S—a Nite ) Ize Innovation holster
Building on left is 125 meters and building on right is 30 meters.
Hi did not think that holster would but had long lost that holster may pick one up
Hi. A noob/stew-pid question.
What do the acronyms XHP-50.2, and SST-20 stand for? “Extra High Performance/Power?
Super Standard Transmittance?”
Also, what significance are the numerical designators. Especially the .2?
Thought I’d ask. :student: not
https://www.cree.com/led-components/landing-pages/xhp “Cree Extreme-High-Power XHP LEDs”
As for the SST… I have no idea. Maybe contact them and ask
SST - According to the datasheet it means “Surface Mount Package”. Though they used SFT for flat surface-mount LEDs too. By flat I mean that they didn’t have a dome.
.2 - this just denotes the second generation. In all Cree LEDs this means a completely different LED with much different properties. Sometimes better than the original, sometimes worse, often it depends on application.
Fielding a few more questions, please.
What does a dome on the LED do, protect, and desensitize? Is that why domes are
Shaved, to allow full Lumens to shine thru? :innocent: Allow more throw?
Is it a noobe possible task?
No, it improves light extraction.
That is: die emits some light, it enters silicone dome or a flat piece of silicone. Then travels across the silicone and hits silicone-air edge. At this edge some of the light passes but some reflects back.
With dome, light hits the silicone-air edge more perpendicularly. This reduces reflections and improves light yield.
Typically domed emitters give 10-20% higher light output.
But they also give less throw, much less.
See this to get a full explanation:
The dome basically acts as a lens that enlarges the size of the LED’s phosphor relative to the reflector.
How easy removing the dome is depends on the particular LED. Some can be sliced easily, some should have the dome removed with a chemical solvent as physical cutting will damage it.
Do many people here really examine those highly technical graphs (like CCT comparisons over runtime) that the most technical reviewers put in their content? I am impressed with the scientific and mathematical minds who endeavor to produce all of that work, but… I often wonder if it makes sense to only a very select few of BLF members. It often feels like such highly technical reviews require far more effort to produce than the very light given is even worth.
I do appreciate some graphs, like runtime on various cells, but in the end the aggregate performance numbers are my main interest (total runtime on each brightness level).
Data are always good.
If people are willing to make those graphs, I’m always happy to have them. I’m an engineer and usually know how to interpret the graphs. If not, I can always ask :slight_smile:
Bear in mind that those graphs also supply the information that the “select few” can use to answer questions accurately and give good advice to the rest of us.
A lot of that info is relevant to choosing what emitters/drivers/optics/etc. work best in combination. For example seeing that the Nichia 219C has a low forward voltage means you do NOT want to put it in a single-emitter FET light. Some of the other info shows that new emitters render old ones obsolete (or that they don’t) based on things like color quality too.
Furthermore it shows how LED tech is advancing and just what kind of improvements/disadvantages things like the jump from the design of the XHP50/70 to the .2 versions offer.
I have both the Astrolux ft03 versions. (sst40 & xhp50.2) I’m looking to dedome one of them. Which would be the best to dedome?
Keep the sst 40 dome on the ft03 I cannot speak for the 50.2
The XHP50.2 will be an easier dedome job since it’s a flip chip (no bond wires in top), on the SST-40 you’ll have to be cautions of the 2 bond wires plus the ESD protection diode.
Also, if the sst-40 in your FT03 is anything other than cool white it’ll be impossible to replace if you mess it up.
