Any time some muggle grab my anduril light they enter in ramp config within 20 seconds accidentally. I think Aux led control can be replace with the ramp config . like 4C and 4H to set aux leds and 7C to ramp config, beacon config…etc.
Aux LEDs could be used to help make configuration changes, and to help know the current setting. Would be better than tap-dancing on the button or waiting for 42 blinks
Thanks for your answer. I can understand your reasoning too.
It’s just in the case of the mode settings/ output levels, I usually set a light up to my liking then that’s it.
Very seldom is the configuration changed and if I do want to change things around it is no big deal entering an extended deliberate sequence to do so.
As ZozzV6 also said, giving an Anduril light to an unfamiliar will usually end up in the settings being messed up on return as they just keep on a clickin’ away. 10H or so would take them much longer to figure out
I think it is more confusing to learn colors but in battery check mode it could be useful to blink Volts and tenths with different color. Like 4.2V is 4 blinks green and 2 blinks blue.
We’ve been working every hour except sleeping since last week to build the flashling kits.
Hopefully, the reflashing kits can be for sale without too much waiting.
The programmer, cable, and pins are all included in the kits, all you need you to
do is to take the kits out from the box, connect it with you PC, install the software, reflash ,done.
Hopefully, the reflashing kits can be for sale in a week time.
Now, I would like to write an instruction to explain the steps on how to reflash,
a video would even be better, but I’m afraid my English is not good enough for the instruction video,
I hope some native English speakers could help to shoot the video.
Perhaps a lock on configuration mode so when we get it set up like we like it it could then be locked to prevent accidental entry? 22 clicks to lock out Configuration. (Ok, so I Love Titanium! [and have always been a Bob Hayes fan])
In the example above it was more to show how color auxs could improve a UI like NarsilM. The bad part of NarsilM is that you have to sit there counting blinks while holding the sheet … buzz 1 blink… buzz 2 blinks … etc. If you lose count you have to start again, plus if you change the wrong setting it is not always obvious.
(I do not say ‘bad’ as an insult, it is inevitable to have this type of configuration process when we have only one input and one output).
Arduril does not function exactly like this - however there are parts of the UI which require counting blinks and so forth, so I think something similar could apply.
4.2V being displayed as 4 blinks green, 2 blinks blue …. (or same for temperature) yes, I agree good idea.
With time I think UI designers will think up dozens of uses for colored aux lights.
