Mode: 6-mode Low / Medium / High (It has mode memory function), Double click within one second turn to Turbo mode (super bright mode), thrice click Strobe / SOS, long press 2 seconds to turn off.
from here- https://www.aliexpress.com/item/33004236817.html?storeId=1242423
I keep getting tempted by this one. It looks like it could be a great light, but that long-press for off is a killer (and maybe the stated low level). Otherwise it seems nice: compact, 21700, temp regulation, and USB-C. I’d just replace the driver, but I’m guessing the charging circuit is integrated. I guess the best I could hope for is a SOIC8 MCU that could be swapped out.
Anybody have disassembly pics of this? I’d love to get a peek at that driver before pulling the trigger.
Or… Freeme, do you think your connections could hook me up with a review unit? It seems like no one on BLF has first hand experience with this light. Maybe a review could spark some interest.
Sorry to necro, but for anyone that ended up buying this… Is the driver glued in or is it held by a retaining ring? This light keeps popping up in my mind like it’s calling me, needing to be modded.
I’m curious, do you say this because you feel the body to be off low quality? Or the driver/UI? I know the driver is not great, it’s just an unregulated FET driver with a bad UI. But custom drivers/UI’s are kinda my thing. However, if it’s the body/host that draws your displeasure, that would be good to know!
