TK's Emisar D4V2 review
Just wanted you to know that your reference didn’t fall on deaf ears. :wink:
Never mind, got it (was in spam folder). Thanks, I'll see how it goes.
Come to find out, my AVRdude also doesn’t support the Attiny1634. Terry Oregon, would you be able to make the file available?
I’ve got everything ready, even some .bat files to make the flashing easier. Just waiting on Oshpark to finish making and then ship the keys. Didn’t think this would be an issue.
Hank,
When and how do we begin ordering these flashing kits?
Will you be reaching out via email to everyone with a first batch light, so they will have the first chance to order at the lower price?
(BTW, I have two of these muggle bugged DV2s,and have not yet gotten a email warning me about the problem. I hope that I am the exception.)
i’m in the same boat. haven’t heard anything on the glitch in my email. would also like to order my reflash kit asap. this is a great light, with an awesome UI…… when the glitches are worked out so i’d like to get mine in full, proper working order as well.
(My 69th post, giggity)
BREAK OUT THE BAND !!
Finally got it to work with Hank's files. Actually, at first, Hank's files also gave me the t1634 error. However, when I rebooted my computer, everything started working. I suspect that Windows was using a version of avrdude.conf that was in it's memory. That original "conf" file is where support for the all the chip parameters are stored. I think rebooting caused the avrdude.exe to use the new avrdude.conf file. That's my theory.
This is my test jig, the key-pcb is hard-wired to the USB board. The USB board was from Amazon HERE, so I can confirm it works - and it looks exactly like the one Hank is using. I would wear a ground strap if handling these exposed PCBs (they are shipped in anti-static bags).
[quote=BabyDoc] Hank, When and how do we begin ordering these flashing kits? Will you be reaching out via email to everyone with a first batch light, so they will have the first chance to order at the lower price? (BTW, I have two of these muggle bugged DV2s,and have not yet gotten a email warning me about the problem. I hope that I am the exception.) [/quote]
[quote=FritzHID] [i'm in the same boat. haven't heard anything on the glitch in my email. would also like to order my reflash kit asap. this is a great light, with an awesome UI..... when the glitches are worked out so i'd like to get mine in full, proper working order as well. (My 69th post, giggity) [/quote]
The answer is just a few posts above.
I assume this will include those who ordered from MTN Elec. in USA…?
Or will MTN stock them too?
Thanks!
Hank has given me permission to post a link to the AVRDUDE installation file he sent me. This was uploaded to my Mediafire account (Hank has problems using google docs in China).
http://www.mediafire.com/folder/ikdiocyfn20zg/Hank-Files
That all sounds great. Thank you!
Do you know when we will be able to place orders (or pre-orders) for the kits? Will it show up as a product on your web site?
lots of questions, clueless about this flashing hardware, software. I do see many knowledgeable folks struggling, requesting upgraded versions of things. I understand the ‘kit’ will be all set up, just plug it into a USB port. I’m not sure how those pins stay on the right places? Where does one get the software, will Hank supply that as well, or is that link that posted a few posts ago the software? And I have a Macintosh, was that for a Mac? Hank said easy peasy, 20 seconds, his daughter could do it.
I’ll keep reading here……
Thanks for the reply.
Is this change only for the D4v2, or is it a global change for Anduril firmware (starting which date release of Anduril firmware)?
It will work with win 10 1903 64 bit ?
I figured out on my own by reading posts what to buy, download and how to flash a few months ago when the Q8 was the hot topic. With clear instructions and the right equipment it really is “easy”. I didn’t find it “easy” nailing down all my (stupid) questions, but digesting tons of posts…I finally got it.
That being said…
If the EXACT hardware and software is provided, and a special thread is created to describe the supplied hardware/software necessary, I suspect it will actually be very easy to follow along and get a successful outcome.
Much of my time spent and confusion was from putting together different dated posts that sometimes didn’t correspond to current reality. I also found it more mechanically tedious than mentally difficult. Tiny wires falling off, putting wiggly wires in tiny holes, programming clips that didn’t seat correctly every time…etc.
Once actually set up with all the right stuff, it will/could be as easy as Hank describes: plug in the USB programmer, start the programming flash program, direct the flash program to the hex file you want/need, touch the six pins to the six D4v2 vias (you will have to hold them there with a steady hand), send the flash command…and if it’s successful, the light will be programmed in a few seconds and ready to power up with a new UI.
There is definitely a learning curve when teaching yourself, but I suspect most if not all will not have much trouble if they are just mindful to follow the steps.
Terry Oregon had successful results just a few minutes after finally having all the correct info and programs necessary. I liked how he overcame the pin key being too thick by angling the pins!
After I figured it out, I flashed my two Q8’s and my DS4 in under 30 mins, and most of that time was spent futzing around with the wires—the actual flashing was pretty straight forward and quick. We are going to discuss this for days, but when people get the kits and instructions it will all be over quicker than Christmas morning.
It’s actually kinda neat that you can be a part of your own little Tesla moment—hacking the UI of a sophisticated and complex torch.
Mine is Windows 10 1803 64 bit. I think you will be OK. I installed the USB board drivers using the zadig program, as described HERE. BTW, that's a very useful post from BLF member amars7
I concur, it was only time consuming for me, because I had to pull all the info from multiple sources. I just liked the challenge of figuring it out myself. What comes from Hank should be MUCH more straight forward.
thanks for the infos. sounds good…
I would get me one of these… with ANDROIL or ANDUROID.
Funny story:
I had my car at the mechanic recently checking on the engines ‘brain’, that is how the call complex car electronics in Greece.
He said, you are very lucky your can only has one brain. (I drive an old car)
Modern cars have 25.
Hank’s link to google drive is working but if the link is just copy/paste as text, the forum is turning it into a link but changes a character in the process which makes it not working.
https://drive.google.com/file/d/1XEVlyF9X5atOdHOB9PVObWHJOJ6_dEaq/view
Android, Android… What about flashing the firmware using an Android phone? And indeed, someone compiled avrdude for Android and wrapped it in a nice GUI: https://play.google.com/store/apps/details?id=ru.zdevs.zflasheravr
You just need a USB OTG adapter, select the correct parameters and press GO! Here is a screenshot of what you have to configure:
