You can see the archived poll results on the Wayback Machine:
https://web.archive.org/web/20221220093741/https://budgetlightforum.com/t/-/72845
Next mode memory
Voted!
There was once Convoyâs driver with setup: 1-click, 2-click, 3-click, you could program two firsts light power and third one allowed for some blinkies or moon.
I donât know why this soution did not spread wider. IMHO: a great solution, you can easily access any of modes you desire without going the âclicky-pathâ. And I realized that very rarely I need more than 3 modes.
Donât you think that n-click based driver would be nice? Even going to 5-clicks you can access any of modes right away.
In a stepped light I prefer L-M-H-T-L-M-H-T
The reason for this is simple: I know what will happen when I click the button. It is always the same.
âWave patternâ in a 3-level light is slightly annoying (L-M-H-M-L).
âWave patternâ in a 4-level light is very annoying (L-M-H-T-H-M-L).
Definitely L-M-H-T-L-M-H-T.
BUT:
Triangle instead of sawtooth.
Problem is: You never know what the next mode would be if current mode and direction are memorized (by f/l, not by human brain).
Shortcuts to moon and turbo FTW :+1:
L-M-H-T with memory mode.
Voted âLow> Med> Hi >Turbo >Low> Med> Hi >Turboâ!
Ideally, the possibility to go UP and DOWN on modes (ramping style) would be nice. But normally I prefer the above mentioned sequence. Actually, I did not buy some lights from a certain brand [despite I like their designs a lot!] because of the L-M-H-T-H-M-L sequence :zipper_mouth_face:
Programmable UI like Bistro that let you choose modes order, low to high or high to low, let you choose numbers of modes, enable or disable memory, etc.
L M H T H M L is terrible for me.
Mode memory is fine, as long as there is a shortcut from off to low. (I like a shortcut to turbo too, but itâs not as important.)
Really irritating to not know whether the next click will be brighter or dimmer . You're wrong 50% of the time So half the time the light is a disappointment .
Also, very important that location beacon (flashing red light on button) has much lower drain in future Skilhunt flashlights.
On H03 the drain is like 2mA
BTW, AndĂșril ist very good at that. Click and hold for up, Doubleclick and hold for down. Best method when being limited to a single button UI imo.
Sawtooth for me!
Out of those two, I prefer LMHTLMHT. Itâs easier and quicker to get back to a low setting and as it was said before, you donât know if the light is going to get brighter or dimmer when you pick it up.
With a stepped mode light, I would prefer Hold from off to get Moon, hold to scroll through LMHLMH, double click to Turbo whether on or off and a single press to turn it off. That would suit me just fine.
T-S-H-M-L
I know the poll is pretty much decided for at least the few of us that voted, but Iâd like to see more votes here, soâŠ
BUMP!
BTW, I voted L>M>H>T>L>M>H>T and I prefer also the following:
Direct from off to lowest mode
Donât care about memory
