No they are not suitable for flashlights, just the extreme good CRI makes it tempting to try to fit them anyway. But I like the Tool Ti as it is now with peach-coloured corona. I may make a 4000 lumen quad flashlight out of these as well, with OP reflector and heavily frosted lens.
Thanks for the info Djozz, my copper Tool looks to be the same as my EDC01, iād rather they were like your Ti Tool!
I really like the look of these LEDs, appreciate the review. Do you think having the LED extend into the reflector rather than sit behind it would make much difference?
It has a rather defined hotspot actually so the focus seems about right.
If you do this mod you must realise that the led-minus pad is soldered onto the thermal pad of the XP-board and you have to make electrical contact between thermal pad and the led-minus of the ledboard. I did that in a rather clumsy way that I do not recommend (a little wire that of course got in the way of the center piece.)
I looked at the color spectrum in the datasheet. I still see a peak at 450nm (blue wavelength). I thought these use violet pump instead of the typical blue. But still the amount of blue light emitted is incredibly low for the CCT. Great for use before sleep.
The pump is nearly violet though, looks like about 420 nm, just like the cool Optisolis CCTās. The peak at 450nm I would expect to be the first fluorescence peak.
First of all I do not like to exceed recommended ma.How long will leds last at 400ma,more than twice that recommended. 3000 hours,5000? I think not more than that. Unacceptable period for me.
Better to get 1w and use them at 250ma they will last at least 40.000 hours maybe even more.
Midpower leds are usually mounted on FRP boards, my test on an MCPCB may not be completely representative for normal use of the led. Further, flashoholics (the main target for my tests) are not usually concerned about what happens after 1000 hours. ,So on top of my test results, what current will be ideal is largely dependent on what you will build.
Iām still using my HDS with stock Seoul SSC P4 for its very good CRI despite its poor lumens to size ratio.
I mentioned its peculiar beam pattern here. Once I got it, it stopped my flashlights quest for many years.
Iām a bit puzzled by McGizmoās measurements about the CRI R12 = 66.1 because to my eyes it has deep and dense blue colors rendition, better than most CRI90 LEDs. Blue colors look better than with a SST20 4000K to me.
@djozz
Yes you are right, I shouldnāt have said that it has better blue colors, shades look more saturated with a red/magenta hue shift that is better to the my eyes than a yellow hue shift but effectively there are noticeable shifts that might lower its R12 rating, roughly by eyes I would say a positive chroma shift and a hue shift toward magenta.
Aquarium keepers are desperate for long life . Those who undestood the difference between āsunlikeā light and regular blue leds or RGB/WRGB looking for more powerful than 0,2w. Seoul Semiconductors sunlike COB is too powerful and is CCT5000. People need cold white with high CRI and sunlike spectre. From 1 to 6w is the best suitable for aquarium keppers. I will need at least 24 strips of 0,2w leds for my aquarium.It takes too much space.
Looks like you are in hobby for a long time,so in case if you find a market place let me know.
Many people will bless you:)
Thanks.
There was rumour a while ago (I hope it is not cancelled in the meantime) that in the future Nichia will come with high power Optisolis leds, if true they may prove ideal for your purpose.
