I think I’ve seen the number of the highest regulated level somewhere in this thread, but I lost track of it.
Does anyone know what is the highest regulated level (7135*3 maxed out) and how many clicks do I need to do to set it to that level?
Tried searching but couldnt find the info. Does anyone know what tint bin is used on the sst20 4k emitters? I am finally going to pick one of these up, just undecided on Nichia or sst…
Easy enough to put a lee filter between the optics and lens. Fireflies seems to be using different bins at different points in time during their production. Early on when during their first batches of ROT66, I received neutral/rosy SST20s. Those with a lee 804 filter is amazing. Very recently I got a Cu E07 with slightly green SST20s. Even with a filter on low modes, they’re just okay.
I’m pretty impressed with the results. Dropping DUV by 0.0020 is quite a difference. That amount of green reduction is between a Lee Filter Zircon 804 and 805. However instead of losing 15% output, it actually gains 2% output.
Jack told me that he is adding 20 degree E07 TIR optics for free with my order so I guess that some people might be interested to know about it.
The current E07 optic is 45 degree.
I’m waiting for it so I don’t know if the more throwy beam will look good.
I saw a more throwy optic on a site that I thought might fit the E07, but it was just a little too large. I wonder what kind of optic Jacky got.
I’d be interested in some for sure.
I received the UCL lenses for my E07s, and the are more clear than stock. The effect of the new lens is about the same as a LEE green minus 1/8th. The lenses are thicker though, so you will have a small gap between bezel and heatsink— it’s very small.
Also 45 degrees sounds very floody. I think current optic for ROT66 is 25 degree, and E07 is very similar.
This optic (KingBrite) has the same 4 legs footprint than the E07’s one and have a wide range of beam angle : 10°/15°/25°/30°/45°/60°/70°
I’m not sure of the MOC.
I would have wished FireFlies to sell a few of them with the E07.
The E07 listing has always said 25 degree TIR but it will be interesting to see what you end up getting. Maybe something is lost in translation but either way more options are always nice
I found out the mysterious reason why E07 drops in output overtime. The spring flattens out after being compressed and doesn’t return to the original length, which means it won’t push as hard on the cells. The weaker contact results in more resistance and lower output. I took some measurements with these fully charged cells. The 18650 cell uses a 21700 adapter, which makes them a good bit longer than the 21700 cells so the spring pushes harder on the 18650 cells.
This same E07 used to measure around 7,570 lumens with the same 30T and 7,017 lumens with the 40T. I swapped the tail cap with another E07 tail cap that is used less and the 40T measurements jumped from 5770 to 6000 lumens. There’s a possibility that I might have tried a 21700 protected cell which compressed the springs too hard causing permanent deformation, but I don’t remember. But now I know to never put protected cells in a flashlight not designed to accept protected cells.
These springs are not bad and all springs flatten out over time to a certain extent, but if Fireflies ever find any springs with better mechanical properties, they can sell them separately as an upgrade. There’s nothing we can do with the spring on the driver side but if Fireflies provide a longer tail cap spring, that will make up for the loss compression.
