Of course, another way is to just leave them as Incans. After all, these are all just shelf queens anyhow. That way I wouldn't have to screw with all this crap. Just dress 'em up and leave it at that. I hesitated to mess with the AA/AAA, because basically, they are a real pain, but I just thought the trio would look good on a shelf. Make the 2D into a 3AA XM-L and leave the others as is, except for dressing them up. Not a bad idea really...
You can direct drive the XML in the 2AA with a single 14500 and a single AA dummy cell.
The AAA light, same thing. One 10440 and a single AAA dummy celL Each setup will give 4.2 V
Ya, that would work. I don’t have any Li batts or chargers. I could always make the dummies and then sell them and let whoever got them worry about getting the Li batts. It’s an idea.
For the AA and AAA lights. FD-A Boost Current Regulated 0.7V~4.2V 1.0A Flashlight PCB
I happen to have One of them. Does anyone in the US happen to have one of these? I hate to order from KD and let this all sit for three weeks, but if no one has one, I will have to...
Thanks
Is that driver new? I've been searching 2AA drivers a long time now and the only one that seemed good to me was the DX one. This one seems pretty nice, tho its only 13mm..
Lots still too large for the AAA. Also, keep in mind that even NiMH AAA cells would struggle to put out the amount of current needed to keep this thing pushing out that much output. I'd use the 700mA driver on the AA and the AAA driver from Illumination Supply in the AAA cut down to 1XAAA. If you don't want to cut it down then I can make a spacer and drop it off with Craig to send to you along with that driver.
1A at LED needs ~1.8A with two AAA’s, Eneloops can handle that just fine (in fact, they handle up to 3A just fine)
PM me if you still want one. :)
Not too large with the AAA. It will be done just like the AA that Match modded (I have too). 13mm will go right in the head, after boring it out.
I have used AAA Eneloops in P7 lights for 3-4 years. In fact I still have one. They work well and they last for about 10-15 minutes DD on a P7 C bin. I don't think it will be an issue with a 1000ma driver. They take much more than they are rated at, just like the Eneloop AA batts. It won't be a long lasting light, but it should still do 1/2 hour with a 1000ma driver (depending on how efficient the driver is and the resistance in the setup).
I certainly appreciate your offer and I am constantly amazed at the knowledge here. It really is very nice to recieve these ideas and it makes me think. If there's any problem with the driver setup, I will let you know and will try the one you suggested.
Thank you
I don’t think it’s new, I’ve seen it for a long time on the KD site. I got it for an AAA Copper light I was going to make and never did, since it’s the smallest I have seen that gives at least 1000ma, which is probably really 800ma at best.
I've been thinking about a little file work, like is done on knives. What about a pattern like this?
I only did one and I can change it to fluting, but I wanted some opinions before I commit the whole light to it.
A cannabis plant? :P
my first though when i looked at it :)
I can't fully envision the light with more of those file designs but I actually like it so far.
I prefer your fluted lights, but a green version could be the "Cypress Hill" edition.... S)
@OL: Must have hidden from my eyes then.. I cant even find it on the aqualab driver list.
I like the cannabis leaf btw, gotta take you a while to make so precise little strokes..
Have you ever tried making your body-mods with an engraving tool for the dremel?
Ok, I took some time to find out if the Driver would really fit the AAA light. Here's some photos:
Here's all the pieces.
I bored the head with a 1/2" drill and then used my rotary tool to just take a few more thousandths out.
This is the depth from the top edge of the head, that I bored out. 11.97mm, call it 12mm.
The driver is 4.64mm thich.
The modified Reflector measures 5.03mm and that only leaves me with 2.3mm for the Emitter and Star! Not a lot of room and it's going to get hot fast! I cut the fins off the reflector and used a coarse sandpaper till I cut off all of the base of the reflector. When you sand it down, you open it up to the major diameter in the bottom. Plenty big enough hole for an XM-L.
The AAA body had a non-threaded taper on the top edge. By eliminating that taper I gained over 1mm and that lets the body screw in further. I am at 1-1/2 turns in, so it should work well. The top edge now works as the ground contact to the board. The outer ground ring on the board fits perfectly against it.
Here's the board in place. I did have to sand with fine paper, all around the edge of it, to clean it up and remove just a few thousandths.
Here's the reflector in place and you can see there is not a lot of room here. I think an XM-L AAA Maglite is stretching things a bit. I will be using a thin copper pad behind the star and a copper sleeve between the star and driver, so it should conduct some heat to the head itself.
More to come, later..............................
Ok, so the driver is history (toast is more appropriate), and this is now a DD light. Here's a couple photos.
I used the shell of the driver for the contact plate.
It's just a normal copper pill, like I have shown in the videos before. The reflector is OP.
100W (rated 450lumen, when did they start rating light bulbs in lumens?), for a comparison.
AAA light with 2Alkaline batteries direct drive.
White door, the only thing white in the garage. The LED is a T5 3C 5000k, from Illumination Supply.
I'm done with this one. Next is the AA light.
No, actually it represents the rising sun. Appropriate for an XM-L AAA Maglite.
Mary-J-Wanna....... No I don't, yes I did once (or twice), I was young then, can hardly remember....
I tried once, trash man took it. I don’t have the touch for that. Any pressure at all and whoopee!
You make a nice unplanned design across the surface...... Of course, I have done that with a file too. I think the trash guy knows now and he looks for lights when he comes by... For Xmas, I'm just gonna leave them out for him.
