Reserved.
So what size are the slots?
Width should be in line with their charger models. You can simultaneously charge up to 6pcs of 18650 for sure. Noticed that slot 1 and 6 (2A)are wider than its adjacent slot. Maybe Lii-6S has enough space to accommodate 2*26650+4*18650. I can measure when i get mine in a few weeks time.
Interested.
Are there pictures of it actually charging cells? Does it tell each cell info?
I can't find any at the moment. I will post mine when i receive it. Quality should be similar to Lii-500S.
Sent. [quote=Asue] Interested. [/quote]
Interested
No, not if the photos and graphics are of the genuine charger, which they should be. The pictures make it clear that the display shows info for only one cell at a time, like the 500 and 500S. It appears that you press one of the middle 4 buttons to toggle display and control between pairs of bays and otherwise operate it much like the Lii-500 Engineer and Lii-500S.
Looks good i am interested but ill wait for HKJ to give the all clear.
I think the 12v 3amp AC-DC adapter will be struggling to fast charge 3 cells at 2amps plus other cells at the same time if it even lets you do that.
Absolutely interested.
You got mail. [quote=Maraque] Absolutely interested. [/quote]
Ordered one. Thank you.
Much appreciated. Put in an order for one. And surprisingly it has been shipped already.
August Charger.
Interested.Thanks
Sent. [quote=delete] Interested.Thanks [/quote]
Interested. Thanks.
Interested
interested
thanks
