Collecting interest for a Sofirn C01 host version
I’ll do a couple hosts.
I’m a little confused as to why they can’t produce the 5600k version again. I’m seeing the link to the used LED on the C01 page as being available. Is this not the case? I wouldn’t want a host, but I would definitely pick up a C01 even if it was $7 or so if that is actually the LED and it is actually available at that price. Here is the link I found in the original thread: here.
Jos, would it be possible to add some alternative LEDs to the Yuji BC that would fit into the host? Maybe this could increase the interest even more. I must admit I don’t have any idea about good 5mm LEDs. Bedankt! :-)
I had a feeling that there were more reasons to stop the C01 than just availability of the Yuji leds (the more popular 3200K led is indeed sold out). Maybe they simply wanted to move on to the C01S which is the type of light that Sofirn was planning in the first place, even before we suggested to do the C01.
Look at this post:
Someone that is more interested should PM him and see what he ended up sourcing
Personally I have a small collection of 5mm colour leds that would make fun lights. And the very bright white Nichia GS may work well too, especially if you manage to mod the current. I have them from leds.de : https://www.leds.de/leds-komponenten/bedrahtete-leds.html
But there are more sources for 5mm leds too, i.e. on aliexpress and ebay.
He is still on the hunt for good quality but it needs prototyping and testing. I (and maukka) tested some first prototypes for him and the tint/CRI/output were good and comparable to the Yuji leds but the beams were a bit uneven, which could very well be because they were prototypes (sort of handmade). But then the factory stopped communicating and now he found a new source, and some new testing must be done again. If he succeeds in getting them done and selling them they should be very good for use in the C01 host.
in for at least 2
djozz, it might not be relevant to this discussion, but 5mm LEDs are available up to 100mA rated (and maybe higher). They can be bought through eBay as 1/2 watt (even though it would be more accurate to say 1/3 watt). I don’t know about high CRI though.
For these 5mm LEDs, unless they mention specifically of the CRI, you can assume it’s at 70. Part of the reason is the material cost and the fact that the efficacy will drop ~20 lm/w going from 70 to 90 CRI.
If you want to go for the highest output in 5mm package and CRI is not your concern, you can always try that out.
This Australian site appears to show the 5600K as still in stock, but not the 3200K:
https://www.ledsales.com.au/index.php?main_page=product_info&products_id=2062
Yuji themselves also still has the 5600K in stock, in their usual quantity of 1000 pieces minimum.
https://store.yujiintl.com/products/bc-series-5mm
I don’t know of any sources that still have the 3200K Yuji.
As long as we’re on the topic, I looked up a few other options for LED’s you could put in a 5mm host like this.
LED Supply (US only?) has unspecified brand and unspecified CRI of 5mm LED’s in cool and warm white, in addition to numerous different single color options, UV, and infrared.
You can also find combined RGB LED’s with a simple built-in controller that changes the color. Depending on the seller and the type, they are described as a “rotating”, “flashing”, or “dynamic.” An example here, including a video in one of the reviews:
https://www.amazon.com/microtivity-IL604-Slow-Rotating-Resistors-Pack/dp/B007RO9X82
Same here. Hot rod 10440 C01S would be nice. Just like 10180.
Do you know which led nitecore tube using?, i think it is a good choice for this host.
Btw, im not interested in this host, a few buck more i can have complete c01s with great tint and higher output
I’d take at least 2 (if black). Thanks!
You can talk about high power and lots of light here, always welcome :slight_smile: , but that is just not the C01. The 5mm led requirement will limit this light to under 100mA and under 50 lumen, max. The C01 is about low power long runtime endless abuse always works. Even without potting.
And this host allows some fun versions like colour leds and UV leds. I have some pretty high power (for 5mm leds that is) Nichia cyan leds, that would be a fun version, or a red led for seeing in the dark without destroying your night adaptation.
How long do the 5mm led wires need to be? I trimmed my only yuji to fit a coin cell light
Put me down for two (2) hosts for now.
If too short, solder stiff copper wires to it. When it fits, pot the whole compartement to give it stability. I had one unpotted C01, it’s really easy to do.
I’m afraid that you will need a bit of length because the solder holes are at the side of the driver while the led sits in the middle on top of some other components, you may not need the full length but the wires do need to make two bends.
What’s the driver diameter? Perhaps someone can make a new Li-Ion only driver for this and let people burn up LEDs if they want to. :innocent:
