【convoy】H4 and B35AM options are updated
Ah whoops :slight_smile:
i sell L6 host ,too ,i dont want to add link in my store ,
you can order L6 flashlight ,and note ” L6 host” ,then i will adjust the amount
Thank you for reminding me, I changed it.
Thanks, PMed
The XHP35 driver, is it for 12V LED’s ?
yes, 12V
Apparently H1 UI updated for the traditional Olight/Thrunite style UI.
Interesting… Can now look into emitter swaps for high CRI. Would suggest a new headband with over-head strap, though.
Interesting, where do you see this?
https://old.reddit.com/r/flashlight/comments/ck5r0y/convoy_h1_new_updated_ui/
https://old.reddit.com/r/flashlight/comments/cglpzx/nld_convoy_h1/evh3bxo/
Got a post of mine re: the UI responded to, so hey, if that’s accurate, everyone should know :slight_smile:
Hello Simon,
Does the XHP35 HI 4000K B4-40E have 90 CRI?
not high CRI
I would suggest XHP70.2 with 21700 for floody beam profile.
High CRI led is really what a headlamp should be! Now is “Durian” season, picker need to see clearly at night in search of durian. Some time green durian and green grass make searching a lot challenging. we need a good colour contrast and also a good battery which Convoy already have…great! Looking for an upgrade version…
Swap out the MCPCB in the H1 for a 16mm SST20 or LH351D :wink:
A host headlamp? maybe…
Is it possible, that you fit your 22mm XHP35 Boost-Driver to a 17mm driver board? That would be realy great.
Hey Simon, will you also sell 5000 K version of XHP35HIs? 4000K is too warm for many of us, thanks.
Simon, is it possible to make turbo mode access only after 2 click, from any position(on or off) without memorizing it?
So it could be 0,1% - 1% - 10% - 40% and turbo after 2 click
I see. Then this is bad news for me.
If you could get XHP35 HI 4500K 90 CRI anytime in the future, I would be very interested.
Not 90CRI (and I’m not sure if you will find some with that CRI value), but see here:
sorry ,i only found 6500k 4000k 3000k
