[M4D deal ACTIVE] LiitoKala Lii-500S groupbuy
Banggood is not going to relinquish this sale so that the discount code will work. Was supposed to end on the 12th. guess they are selling a lot of them at $25.
Iā€™m bummed I missed the discount dealā€¦ $21.99 is a nice price. Canā€™t find it any lower than $29.99. Iā€™m not in a hurry so will wait. Hopefully someone will bump the topic with another good price later on.
A small resistor should fix that. Iā€™ve seen people do it on chargers before. Place it between the backlight FETā€™s drain and source. When the charger commands the back light on you have full brightness, when it doesnā€™t you have partial brightness (depending on resistor value).
Are you a member with M4D M4X?? If not go HERE and get signed up. Then check out his deals.
Just be sure not to share the Codes or prices.
Check out the new Liitokala Lii - S6 charger too. 6 Bay charger it is. :+1:
6 bays @ 1000 mA / 3 bays @ 2000 mA
I am, but I was foiled by the brand misspelling thingā€¦ Liitokala, Liitokaala, Liiitokala, LittoKala, etc. I found the 500S on the ā€œLittokaalaā€ now. Thanks!
I think I might go for the 6 bay one, as I prefer tactile buttons instead of touch-sensitive ones.
The only 500S coupon Iā€™m seeing on his website is the one that he publicly stated in the original post of this thread, and it has been dead for quite some time now.
Yepā€¦. :+1: ā€¦ That was why I suggested he check out the new Lii-S6.
Martinā€™s Lii 500S code wonā€™t be valid until either the Sale Ends or he requests a New Code from BG.
Keep in mind the 500S does discharge testing, while the S6 I presume like the S4, only charges batteries.
KuoH
I try to get a new deal
ā‚¬dit
Code works again!
It seems silly to add this, but I meant to say it a month ago :wink: . I found it somewhat humorous that LiitoKala released a Lii-500S charger that will discharge cells just weeks after I purchased the old Lii-500 that doesnā€™t. I needed that feature, spent many months searching for a cheap charger with a discharge mode, and would have paid the few dollars extra to get it.
Fast Test on the old charger is simply useless; no idea what it could be good for. Oh well :beer: . Thatā€™s how it usually goes and glad that they replaced that function with a useful one on the new version.
Iā€™m not a fan of the new display, though it seems to be a trend with some Chinese companies lately to use reverse LCDā€™s. It doesnā€™t seem too bad in the photos, though.
Thanks to Martin for the deals.
You found an original Lii-500 that does not have a discharge test (nor test) function? Thatā€™s a first.
Hmmmmā€¦ Like Pete7874 said above, if you truly found a Lii 500 that does not have the discharge test function; it is an absolute first.
All Lii 500ā€™s have the Discharge Test function. It is the ā€˜NORā€™ Test.
The ā€˜FAST Testā€™ you mentioned above shows how many mA the cell accepts during charging.
The ā€˜NOR Testā€™ is more accurate showing true battery capacity.
Still (or again) on sale at Banggood so the code wonā€™t work. This is the very first time Iā€™m wishing a sale would end so I can order and save some cash :smiley:
BTW, the code has to be entered during checkout in the coupon code entry field right?
Thank you so much!
Flashdeal has ended and the code is working again.
Ordered!
Hi all, can I ask a silly question? Any idea why this unit doesnt come with a LiFePo charging and discharging test like the Miboxer C4000 or the Opus BT-C100 ?
Really waiting for one.
Yeah itā€™s a bit of a shame.
They have 2 new chargers, the 500S and the S6
500S has Test and Discharge modes but no support for LiFePO4
S6 has support for LiFePO4 but no Test and Discharge modes.
A combination of both chargers would have been ideal.
I got 2x LiitoKala Lii-500S chargers this week (thanks for the groupbuy code OP!) and I think I figured out a way to enable the backlight to be permanently displayed. If you long press on the ā€˜1ā€™ button, the backlight should stay on permanently. Well, at least thatā€™s what Iā€™ve seen on mine.
One ordered!
Yes, that was already posted in a different thread some time ago.
Hold any of the slot 1-4 buttons for a few seconds and the backlight stays on.
When they write that 21700 are supported they mean just the flat top ones. In fact, often you read IMR 21700 (which means flat top). But the IMR 21700 is supported by many old chargers! In my old XTar VC Dragon a flat top 21700 fits wonderfully. But if you want to be sure to charge any 21700, then you need bays 77mm long (the Nitecore NL 21700 button top is 76,9mm long)
Also, sometimes even the IMR needs a button top. For example, the new Lumintop GT94X works with IMR 21700 button top.
