Just hooked up a 22mm “D4” driver. It’s in the green one in the middle.
Anduril Runtimes at level 5/7 stepped ramp (should be running on the FET in the stock drivers)
The black D4 (stock driver - XP-G2): 3:15
The green D4 (LX 22mm FET+6+1 - 219C): 2:10
The silver D4 (stock driver - XP-L HI): 2:45
I know the 219C are inefficient, but the stock driver lasts an hour longer before stepping down.
Shouldn’t the FET+6+1 driver with the AMC’s last longer at high output?
If it lasts less long there is a simple reason it’s that it draws a higher current,
you can’t assume they draw same current as they have different ramping tables
Lexel, do you produce any drivers in the 10440 size range - say, 10mm or 11mm? I don't see any listed below 15mm, so I assume not, but I thought I'd ask anyway.
Hi. Sorry if is not the best way to ask. I am looking to drive 3 osram oslom luw with 15 volts. The driver could be square or round. I can glued with ceramic epoxy to a heatsink. I need 4. Thanks in advantage.
I know many have seen that I had huge delay in last 3 weeks literally came not to forum orders
I was barely getting enough time to deal with commercial stuff with Fireflies and Astrolux for example
last 2 days I was so busy completely rearranging my living room to fit a 190Ă—70cm working table to get enough space to work more efficiently on flashlight stuff,
my couch, couch table, parts of the furniture and the cat tree were literally packed with flashlight stuff, also window and floor with a lot of stuff standing around everywhere
Also have at the moment 12 young cat babies that need to be dealt with to get them sold that eats time as they are now 9 and 10 weeks old from 2 cat moms
Twelve kittens around flashlight stuff That must be the cutest FL workplace ever , no matter how packed during all the rearranging. Must be interesting to see the contrast between giving life to all the electronic components and seeing living creatures giving birth to many small copies of their kind “just” by nature and instincts. We would maybe buy a kitten, if we were living closer (actually, we live in a neighbouring country), but I think I will stick with driver(s) for now
Take your time! (Hope my long PM didn’t - or won’t - take too much of your time )
