Thanks. They don’t have the SBT-90 G2 listed yet but seems like the CFT-90 can be pushed harder.
I wonder what flux bin they got. I’m sure Acebeam is not willing to share this info though. They seem to be more lip tight than any other flashlight company I’ve seen.
Given that the turbo runtime is the same 1hr45m on turbo power and turbo eco, one could assume the turbo steps down from 6300-3000lm after ~5 minutes like other large Acebeam lights. Maybe even sooner due to the massive current that’s being pushed to the emitter.
This is the about the same performance Vinh has been giving his MT70+ mods with the CFT-90, but now in a more refined package and probably more efficient driver, assuming acebeam went with 2S2P or 4P instead of 4S.
If the output is maintained at 3,000lm for the 1:45 runtime then they’re achieving a overall output efficiency of >110lm/w, IMO too optimistic for this emitter.
Will you offer same pricing for non-UK distributors in Europe? I have seen prices of EUR 319,00 here in Germany whereas YowCha! offers the K75 for GBP 225 which is about EUR 245 only. There are no customs / tax charges that may need to be taken into account.
UI is a little sluggish to me. Not as fast to change modes or go straight into moonlight compared to my other lights— whether it’s driver VN, Anduril, or Zebralight.
Hotspot and corona are big, around the same size as the hotspot and corona of the Cat6 with XHP35 HI. A very useful and thick beam. I have not taken it outside yet.
Heat is well managed in eco mode. 4 minutes of turbo (3000 lumens) and the light is just warm around the e-switch. If there is any thermal regulation ramping going on, it’s very smooth subtle— can’t really notice anything.
In power mode, turbo gets hot instantly. By 1 minute in, it’s nearly too hot to hold, and the thermal control starts ramping its output down. The 3000 lumens seems very usable, while the 6300 turbo is just a ‘lemme show this to my friends real quick’ type of mode.
I’m not sure why the heatfins half way up the taper of the head, the placement makes no sense. Aesthetically it’s cool, but the heat doesn’t spread to the thin shell holding the reflector in place. It first starts at the shelf of the LED around where the switch is at, and then goes towards handle first. I would have preferred something more like the way Maxtoch does it with the XPro, where there’s a solid chunk of fins just below the reflector. Not having the fins half way up the taper would make the light less top heavy as well. The ones around the button are thick and deep though, and do a good job.
weird such big beefy head and it can barely just manage 1 minute highest? 6000lumens isnt that high u think for this size no ? it should be able run a few min highest without heat issues imo…
