WTS/GB: NICHIA 219B NVSL219BT-V1 R9080 EMITTERS! sw45k, sw40, sw35, sw30
356 posts / 0 new
Joshk
Joshk's picture
Last seen: 1 hour 54 min ago
Man, that “small amount of the 4500k” seems popular.
Put me down for (5) 4500k sw45k d200 L2 r9080.
That should satisfy my FOMO and curiosity. Smile
Joshk
Joshk's picture
If I recall you were expecting test results to be delivered yesterday. What’s the latest news?
SKV89
Last seen: 28 min 2 sec ago
So there is only sw45K but no sw45?
azhu wrote:
SKV89 wrote:
azhu wrote:
SKV89 wrote:
Jon, I actually didn’t know there is a N219b 4500k 9080 SW45 and a N219b 4500k 9080 SW45K. What is the difference? What does the “K” stand for? I couldn’t find any info in the spec sheet.
If my understanding is correct, the sw45k is under the BBL (more rosy) than the sw45. The sw45 could be under the BBL as well but the sw45k is guaranteed to be under so you know for sure that bin is usually rosy. I’ve had a batch of sw45 that was slightly rosy but overall, it’s more neutral white than the sw45k.
Oh that’s very interesting. Is the suffix “K” added by BLF folks to indicate below BBL color bins because I can’t find that in Nichia specs?
The Suffix is actually used by Nichia. You can find it on the data sheet. Not sure if they discontinued the sw45 prior to this though.
!{width:100%}http://andyzhu.com/forums/cpf/219b_chromaticity.jpg!
azhu
azhu's picture
Last seen: 24 min 39 sec ago
PM sent. I actually think I’m about to run out. Need to check stock when I get home.
Buddy wasn’t feeling well and wasn’t able to get around to it. Perhaps by tonight. I’ll update the OP as soon as I have results.
There WAS sw45 as well as sw45k. I’ve not been able to get a hold of the sw45 for a while now so I don’t know if Nichia discontinued that and only went with sw45k.
Need Nichia 219b r9080 Emitters? (。◕‿◕。)
“The Light shines in the darkness, and the darkness did not comprehend it.” John 1:5
blacksunshine
Last seen: 6 months 6 days ago
If there is any sw45k left, I’ll take 5.
azhu
azhu's picture
PM sent
azhu
azhu's picture
*UPDATE: CLOSING SALES OF SW45K FOR NOW UNTIL I CONFIRM STOCK. Feel free to still post qty interested and I will follow up with you should there be any left.
azhu
azhu's picture
*UPDATE: sw40 and sw45k TEST RESULTS ADDED TO OP Smile
Lund1660
Last seen: 2 days 20 hours ago
So it looks like the the sw45k has a lower r9 value than the sw40k. What does that mean and which led has the better results?
BlueSwordM
BlueSwordM's picture
Last seen: 14 hours 31 min ago
The SW40K will have better red color rendition.
contactcr
Last seen: 46 min 25 sec ago
Wonder what current this was taken at
azhu
azhu's picture
These were tested at 200mA.
Lund1660
So according to the test results would the sw40k be the better overall performer maybe just a little dimmer?
SKV89
I wonder why the test result does not show the DUV value. The SW45K seems super rosy according to the graph and the SW40 seems rosy too. Considering it is tested at only 0.2A, at 1A or above, the SW40 should be the better looking tint since the SW45K might be too rosy.
Joshk
Joshk's picture
I seriously appreciate the testing, thanks for doing it.
But I too am wondering if 0.2A data is relevant to the power levels we want to run through them.
azhu
azhu's picture
On paper, yes I would agree that the sw40 should be better in this case.
azhu
azhu's picture
200mA is on the lower end so we can expect the CRI to drop a bit when more current is used. Still these emitters should prove themselves to be very nice. I plan on swapping some of them into my lights this weekend to see how they perform. Will post beam/tint shots when available. Stay tuned!
SKV89
And DUV drops as current increases meaning it gets rosier
azhu
azhu's picture
Updated the OP with DUV data. Thanks for reminding me.
sw40 DUV: -0.0031
sw45k DUV: -0.0044
contactcr
This will certainly appease the ever growing pink crowd. Not my preference but i’m the minority. If the lower CCT ones end up closer to BBL i’d get a few
KevinZA1988
KevinZA1988's picture
Last seen: 1 hour 46 min ago
Really looking forward to my emitters now…
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Lund1660
sw40 DUV: -0.0031
sw45k DUV: -0.0044
Sorry for all my questions but what does this show/mean?
twisted raven
Last seen: 3 hours 30 min ago
Shows tint. If it’s positive it’s above Black Body Locus (green). If it’s negative it’s pink.
contactcr
Here’s a random website’s graphic, the line in the middle is “0.0 Duv”
But the lower your CCT is the more the “green side” looks yellow. Same when you go to the extreme other end. More blue mixed shades
jon_slider
jon_slider's picture
Last seen: 1 hour 22 min ago
the k means nice and rosy! its my favorite
the no k is still a little bit rosy
here is the rundown in pictures.. (one page back)
http://budgetlightforum.com/comment/1537374#comment-1537374
and more info
staticx57;5306253 wrote:
Maybe it would be worth deep diving into Color Temp and Tint.
On average we expect an SW45k to be more rosy than an SW45
I think that is an error
I believe this is more accurate
both the sw40 and sw45k have great red rendering, the 45 CCT is cooler white, and its tint is pinker
Lund1660
Can someone tell me how to differentiate the cathode and anode sections? I also having trouble finding a data sheet anyone have a link. Thanks so much.
azhu
azhu's picture
I usually place the LED with the cathode mark (triangle) on the upper right like so: [+] [ ] [-]
But following diagram shows the cathode on the left side, hence the triangle on the bottom left. Hope this helps.
azhu
azhu's picture
Not the most scientific but here’s a general comparison of what the sw40 from this bin looks like:
SKV89
The 219c 4000k looks rosier than the sw40 and sw45 in that comparison. That sw45 is not a sw45k correct?
Also is that 219c 4000k the stock emitters that comes with the FW3A? Surprised how nice it looks considering all the the 4000K 219c I’ve seen in the past are greenish.
azhu
azhu's picture
Yep that’s the 219c in my FW3A. I was also surprised at the quality of these 219c since most of my other 219c are usually more on the yellow/greenish side. Also you are correct, the sw45 isn’t the k variant but it does have some rosiness to it. This was just a quick photo from my DSLR at a custom white balance of 5000k. Results from the camera are never as accurate as how people see these emitters with their own eyes.
