Depends on the temperature outside, your grip, buncha other factors.
As I learned from actual intentional hand-warmers, they can get comfy hot when left untouched, but then once you grab hold and sink away that nice heat, they seem to cool down rather quickly. Same with lights. Your hand (and blood-vessels, etc.) wick away heat which is quite unlike just leaving it tailstanding.
In scorching summer, not as much as a subzero winter.
Etc.
That’s why timed stepdowns are generally Frowned Upon here, vs active temperature control which steps down only only only when needed.
@racoon city: I don’t have the FW3A, so I can’t tell, but I think it’s not as bright as the C8+ on max, which is why I didn’t choose it in the first place.
@Lightbringer: That makes sense. I was holding it, but I couldn’t do it for too long, as it got hotter and hotter.
@BlueSwordM: I have the XPl-HI. Is the SST-40 better?
It has nearly 3x the output with the same X-PL HI emitters. Lumens is total light output and candela is how intense/focused a light is. The C8 has much higher candela due to being a single emitter in a large reflector vs three emitters behind tiny optics in the FW3A.
weird, i have 2 c8+ and they dont get that hot… i mean the xpl hi does what 900 lumens only or so ? the s2+ tho gets hot since smaller size so worse heat transfers… but the c8 can handle highest mode long…
the sst20 version i can imagine gets hot quick since it does 2000 lumens or near that… but i dont have that one.
the l6 is amazing if u want a light that size to shine 3000+lumens for a longer time, in the summer when it was 30c here my light heated up quickly but still u can run if a for a few min or longer depending how hot or cold it is where u live.
mortuus: I'm not sure what's wrong with my lights, if any. varbos: I left it unattended at first, then wait for it to cool, then held it in my hand. In both cases, the light got hot at around the same time.
Strange. The Convoy C8+ shouldn’t get too hot, at least not for many minutes. And if you’re holding it, it should maintain a temperature that is very holdable. I have a couple of Convoy C8’s and they don’t get hot at all, but they’re about 25% less bright than the C8. My Astrolux C8 is brighter than the Convoy C8, and even it doesn’t get that hot for several minutes (I have to keep boosting back to turbo every time it’s stupid timed stepdown happens).
If you turn on your light (to max) and set it down for awhile indoors (where there’s no wind), then I could see it would get hot eventually. I think the solution is to pick it up and use it normally.
When I am holding it in my hand (which acts as heatsink) my C8 Clear (7135x8 XPL-HI) will get pretty hot at the head/fins in 10-15 min. (at 100%)
But the body tube will not get “unbearably hot”. Just warm, no problem.
I would not expect C8+ with same emitter and driver to be significantly different. It sounds a little bit strange to me but there are many factors at play.
