Switch should be recessed.
Mike
Interested.
Good point.
Wow, that’s a nice surprise. Definitely interested. It should be cheaper than FW3A due to conventional design.
I would prefer if power button had standard power symbol, this bunny looks like Playboy or something… but not a dealbreaker for me.
Lockout is super easy with Anduril though so not a major issue for me.
I’m still waiting for a compact single emitter Anduril light, hint hint
I am interested, but need to get all the specs, LED choices,and price.
Any idea how soon these will be available to order?
Interested depending on price and final specs
Why can’t the button be recessed?
No glue please!
The bezel seems hard to remove. Also missing USB recharge to make it truly stand apart from the FW3A
I’m interested and filled out the form. Thanks.
Any info about specs?
what battery will it take?
Looks like bezel ring should be removed like on Zebralights, pry it with tiny screwdriver. Modable anyhow
Interested
Title says “FW3A in a classic body” so I assume specs - emitter options, driver, performance, UI - are very similar to FW3A.
…. aux LEDs
This design is Lumintop’s doing, so It’ll probably be a pain in the ass to open it up to flash newer firmware, or swap LEDs. They’ll probably use that one piece plastic optic, and they’ll glue it together.
I'll have to pass, I've reached my quota of non-recessed side switch lights. If I wanted another, the D4v2 is higher on the list.
I’m interested in the light, but very reluctant to work with banggood again, after they shafted me on my EDC05C order.
Would this be through banggood?
