What did you mod today?
Tomorrow starts camping with the family so I hacked a lantern mod from a Supfire A6, an optic from a Philips household bulb, a perspex washer made to size, a Virens two-pad board, a 1800K 90 CRI Luminus Cube led and a 2x7135 biscotti driver.
I did not manage to finish it with a nice roof and hanging hook, that will have to wait till after the trip. It will do a good job already as it is. :slight_smile:
What no Anduril candle mode? :frowning:
No arms, no chocolate.
No side switch, no anduril.
You say that like its beyond djozz to frankencandle some switch on there. Love finds a way
Candle mode would be appropriate but also a bit kitch, may as well bring a couple of those flickering coin cell led-tealights on vacation. (not the worst idea probably, the family would love that :person_facepalming: )
FW3A? :wink:
Did the ā€œSkilhunt H03 modā€. New Lexel driver that runs Anduril. yay :heart_eyes:
While in the zone, I decided that the red indicator led in the button had to be changed (red = dead). went with a orange.
This had a rather hilarious outcome.
On the low setting the light draws 0,095mA
On the high setting the light draws 37,2mA :laughing:
And on ramping flor the 219C 4000K draws 1,74mA.
So yea, that orange 0603 led is hella bright, and hella inefficient at high.
Some more Emisar D4 and D4v2 lego:
This is:
  • White Emisar D4 head and tailcap
  • Gold D4V2 bezel and body tube
  • Anduril UI with aux led control
  • Lexel bezel LED board with purple and blue LEDs
  • Rubber switch boot replaced with metal switch boot.
  • Emitters: 2x 4000K XPL HI and 2x 5000K XPL HI
I have used one orange switch LED in a S2+ and experienced the same, it drained a full charged cell (only slightly used a couple of times) in 4,5 months
Haha cool. Still way better than this. At 37mA itā€™ll drain itā€™s 3500mAh battery in four days :smiley: :person_facepalming:
vwpieces was a bit faster :stuck_out_tongue:
Today My post delivery guy brought be a glowing package. Inside was a cardbordbox with this cheap hedlamp. It was dam hot but not damaged.
I bought it to upgrade the light on my magnifying glasses. I build something jears ago out of a chap boost driver with a XPG and a tir. But the 2 AA batterys are empty fast. So i was searching for a new option. And this cheap one with internal battery is my victim. But because the led is something terribly white i cut a 20mm XP board to size and put my last 5000K LH351D on it.
Small notice for all that want to do this. On my light + and - are switched. Usually i measure it before soldering anything but this time not. So i had to desolder the board and reflow the led.
Not a huge amount of work but i could have prevented it. I will also add a diffusion film on the glass because i will use the light on very short distances.
First pic is the magnifying glasses i bought the light for. I also added a real leather cover on the headband a year ago.
I forgot to take a pic bevore i dissasembled the light :person_facepalming:
Not often do i get glowing packages delivered
I did not expect to find a 1200mA battery. For about 5ā‚¬ i expected something with 500 or 750mA.
Original the led is soldet to a aluminium MCPCB I have seen worse
And the front side
Now with a 90CRI LH351D on a Noctigon 20mm XP board thas was cut to size
And the front
Tomorrow i will have to grind a bit on the plastic holder to make it fit to my magnifying hadband
But the color is much better and because the die is bigger i now have a softer hotspot.
D4v2 LED change
LH351D 2700K + 5000K 90CRI
3631K - 3882K Duv right around 0.0 w/ AR lens. In another post I measured the stock D4v2 lens vs a plain lens to increase the Duv by approx .001 (not bad compared to FW3A lens)
3,876lm at 0s (18.xx amps w/ VTC5D)
As expected fitting the wires back through the holes is tricky as well as neatly re-soldering the leads back on. Some of the insulation made a sacrifice on the positive wire. A plus is that most of the wires seemed like they had a bit of slack stuffed in the driver cavity.
Is the metal switch any more prone to pocket scorching?
Nice! That must have become an enormous goodlooking flood :sunglasses:
Especially during that minute or so of testing where you have it set up as a mule.
I was a little surprised though cause it seems less floody than my E2L triple 10507. That one has such a round defined hotspot you would think it was an aspheric lens but the quad doesnā€™t have that effect.
Modified some old brass compression fittings.
Do you need a spanner to change modes ?
You use the anti-roll lever obviously
No, this one has a tail clicky switch :stuck_out_tongue:
Donā€™t be silly ,that would mess up the flux capacitor.
