As someone who enjoys seeing things get built or repaired and trying to get a degree in electrical engineering, how did you get all the skills and knowledge to do everything you are doing in the photos?
Nice work, looking forward to the incoming phases.
I am very much like you, I like the creation of stuff. I took the plunge a few years back. I screwed up a wad of cash and threw it at a lathe. Then spent lots of time learning hands on and internet searching. I even asked here on blf .
Machining is a wide subject with lots to learn and there is usually more than one way to achieve something. There are numerous other guys here on blf with lathes and even 1-2 with CNC machines. I am just a hobbyist.
Next I made the bezel
Release the bezel from the chuck and mount the head again with bezel in place ready for shaping
To mount the head so I could work the other end of it I had to make a mandrel.
Great project, is it basically a beefed up Q8 with SSt40?
Great machining skills and pics as well
Nice pp. what is the reflector / glass or are they srk?
you’ve definitely got the hang of that lathe…
Subscribed with interest in this project.
I guess you could think of it as a beefed up Q8, though this reflector might have a bit more throw. Thanks mate
The reflector is bigger than srk. It’s from kaidomain and the lens is from banggood . I’m glad I stepped up in lathe size. This one suits me better Thanks mate
Orsm machining pp. What driver are you using?
I won’t be using any driver DavidEF will is making the stuffing We talked about a LD-M2 so I have made allowance for that to be fitted.
Milling out a flat spot for the switch was a challenge.
It looks good in the pics above but in reality I didn’t have the setup done perfect and didn’t realize because I couldn’t see well enough. The next 2 pics are the actual view angles I had.
As a result the milling was not central. I don’t think the part slipped (which was possible because of the way I set it up) , I think it was the initial alignment of the setup.
I tried to make it right but again I couldn’t see much so it’s still not perfect I moved onto cutting out a hole for the switch. That also didn’t turn out as good as I hoped. I went a fraction too deep and cut into the internal threads This is not such a big deal since it will be covered but I still didn’t like making the mistake. People make mistakes but when they come one after the other…
I didn’t fit the switch assembly until I was pretty much done with the rest of it. When I did fit it… yup I had issue with it
This looks amazing. Please consider making more and selling for profit if it’s successful. Btw the Imalent DX80 and the Olight X9R can sustain those lumens and are not actively cooled. But they are much larger.
Thanks for the positive comment though. For some reason I thought both of those lights were actively cooled. However they do both have thermal ramping. I wonder what lumens they can actually hold after thermal has kicked in?
7 to 8k lumens fir the DX80 and 6.5K lumens for the Olight
The build looks awesome mate!
Its good to see some scratch made lights and lathe work back on BLF
Could you measure the base of the reflector for me?
Looking good so far! That button assembly looks good!
That sounds promising. We might hit the target with this build :partying_face:
It’s not 100% scratch made but I agree, it’s always good to see pics of lights in the making on blf
Lucky for you I didn’t get to the post office on Friday to send it to DavidEF.
Thank you! That’s even better! (didn’t dare to ask you to make such drawing )
I don’t know what you need the measurement for but just one dimension usually isn’t enough to work with.
One of the requests was a tripod moutning point. I wasn’t sure how I was going to do this as I figured I would be machining it from scratch (denoted by the green plate at the base of the 3D pic in OP ). After some head scratching I got an idea. I have a couple of gopro style action cams. They come with more accessories than I need /use. I picked out the one with the deepest hole. In the new host it is a press fit with some epoxy to help hold it.
