Just scored one SC but without the clip. If anyone knows where i could get the replacement clip that would be great.
Thx BLF
Anyone? Help…?
Thx for input!
Are you sure it will fit?
That won’t work! The X5 clip (tge shining one) is not for sale anymore. Only someone who may have one spare can help him, probably!
Yeah, that’s what i thought…dang
Or this one? It is very similar. (EA 11 EC 11 - AA battery)
https://www.aliexpress.com/item/32979129882.html
Now i realized that i should post a question about OD of X5/SC…
That would help to narrow the search
It’s a universal clip. I’m not sure. I’m trying to help.
[/quote]
[/quote]
I appreciate it. Will give it a try
The Skilhunt H03 use a similar pocket clip with an ID = 19.5mm which is the same as the one of the Nitecore MH20. Both are 18650 flashlights but the pocket clip might work on a slimmer body by modifying the legs shape.
NITECORE EA 11 EC 11 – AA/14500 battery. Same as BLF X5 / Astrolux SC.
I have a few clips from Mankers AA/14500 light. E11 I think is the model number. If you think those will work just contact Manker and they will send you as many as you want. Dirt cheap too.
Great info guys, many thanks. I will order few of each since they are cheap and will update 1st post
I’m looking for a clip for the X5. How’d this hunt turn out for you?! TIA!
id30209:Great info guys, many thanks. I will order few of each since they are cheap and will update 1st post
I ended up buying Zebralight H53 clip. Fits perfect.
rjkesler: id30209:Great info guys, many thanks. I will order few of each since they are cheap and will update 1st post
That looks great! Thank you… also passing this on to a fellow flashlighter!
