I have these 14500s now for a few weeks. These high capacity batteries perform as promised. The photo shows the readings after the second time charging.
They’re ‘feeding’ my new Lumintop Tool AA 2.0 and running it on turbo this battery will power it for just over half an hour before it steps down. On high mode you can multiply that by 3. Not bad at all!
Thanks, HJK for the review.
I purchased four of these on Amazon and am very pleased with the cells. They fit my Jet-1, Klarus Mi7, Utorch and Tool 2.0 perfectly.
These batteries fixed the erratic behavior in my Manker T02. That light is picky about battery internal resistance and voltage drop. Even the gold Vapcell 1000mAh cells had issues in that light.
Edited to include the Vapcell in the X5 testing. Seems like the Orbtronic uses the same cell as the Vacell and that they used an extremely high quality protection circuit because the output on the X5 is about the same between the two Orbtronic and Vapcell. The Shockli 1000mah is definitely the new king of 14500. It is both a high drain and high capacity cell, which is just incredible! However, the Vapcell and Orbtronic still has its uses because in lower power regulated lights, you won’t gain any lumens by using high drain cells and the Vapcell and Orbtronic is still the highest capacity 14500 by a small margin in low amp modes that would give you a bit more run time.
The release of the Shockli 1000mah just made 14500 flashlights much more interesting!
I am glad you had received the battery, thanks for your feedback.
Some give away to BLF member(Only ship to USA, can not ship to other address)
thank BLF member’s support, Our company provide some give away to thank BLF member(USA), The give away product now only in stock in the United States amazon , so only available for USA address , please check the following give away product (you can choose a product, leave message or email sales@shockli.com to me, quantity is very little quantity)
NOTE: 1)Detailed product information can be confirmed by searching amazon in the United States
2)Ship Time : It will take 20-25day to reach USA
If you need a product, please copy the following and reduce the quantity of the product by 1, so that you can tell how many give away are still available
Shockli 14430 LIFEPO4 Battery( for solar light)—3pack
shockli 14500 LIFEPO4 Battery( for solar light)—1pack
shockli CR2 Battery( for smoke detectors, Range Finder)—2pack
GARMIN Cycling Bicycle Mount—3pack
Thank you, Simon,
I ordered mine from AExpress and been using it for 2 weeks on my Lumintop AA 2.0.
Such a wonderful brightness and the best thing is its high capacity.
Thank you for this BLF giveaway
I just inbox you and picked the:
GARMIN Cycling Bicycle Mount 3 pack—> 2pack
Anybody knows what are the cells inside the Shockli and Vapcell?
Just curious why only a few brands are selling good quality 14500 and none of them is the actual producer.
Though a friend on Amazon I ordered the four cell button top pack.
The cells arrived with 3.89 - 3.9 volt charge, I did sample one cell with my Opus charger. The cell when fully charged has a capacity at 925 mah, wonderful. I don’t know of any other high capacity 14500 cells on the market.
Much better than “name brand” (NC and XTR) cells I bought in the past. For lots more too!
I use these cells in my JetBeam E10R, Skilhunt H15, AceBeam H40, and Thorfire TG06S. they fit and operate as expected. A great purchase.
BTW when I opened the shipping box an extra flat top 1000 mah 14500 was included.! Thanks Simon
Thanks for your support of Shockli brand, Now we are making a promotion of Shockli 14500 1000mAh battery from Nov 25th to Dec 3th in our aliexpress store , you can get additional $1 off using the coupon code L8P2H9204M1A.
Excellent design indeed, however reverse clicky is not my type of switch.
If they make it with an electronic switch and some kind of ramping UI, that would be amazing.
BTW after I wrote this comment I got the ThruNite T10 II and it’s really nice, the only thing missing is a battery level indicator.
Still waiting for the project Sofirn SP10S with Anduril, fingers crossed.
