i figured it will require sanding down gasket, but there won’t be enough clearance left for soldering those 3 boards in series, if there was a way to reflow these on original 3x xml-2 mcpcb it would have allowed me to sand down gaskets. but i couldn’t find similar mcpcb.
btw, CSLNM1.TG can be used on xpl board, right ? because the 4pot lamp i have uses xpl leds and not xml-2 leds as i originally thought. so maybe i should order some bare CSLNM1.TG and reflow ?
I recently made a fixed thrower with a Convy L2 host.
Parts info:
CULNM1.TG 4040die (LED4Power.com)
LD-A4-20 driver 6A (LED4Power.com)
50mm plano apsheric AR coated (marinebeam.com)
Small RLT collar
Convoy L2 host
GOLISI S43 26650
Testing data:
Driver setting: 4.75A
Current measured at cap: 4.94A
Measuring device: Lutron LX-1108
Measuring distance: 5meters
*Without collar: 16700lux@5m@30s (417 Kcd)
With RLT collar: 31400lux@5m@30s (785 Kcd)*
_ Here is my issue:
While using this desmos calculator made by Enderman Intensity calculator
My theoretical maximum should be 1700Kcd.
However, my result at 800Kcd is half of theoretical maximum! ]:<
Some side notes:
This is my first time ever using a RLT collar.
My collar location should be near optimal because I used 0.10mm shims until I got the highest reading. And also, it is almost double the reading without the collar.
I tried driving at 5.5A and the reading was only a bit higher
35200lux@5m@30s (880 Kcd)
I have only tried one CULNM1.TG. I have another, but I don’t want to change it unless it is highly likely my current emitter is defective.
_
Am I doing something wrong here? Getting half of theoretical max is no fun.
I am already really satisfied with how insane the beam looks. I can see the beam so clearly once it exits the lens.
I will be purchasing the Acebeam W30 because I can’t believe there is something out there with twice intensity as mine!
Are you sure you entered the numbers in the calculator right?
If I base the calculations on this test and use sample 1 as a reference, the calculator gives me 841 kcd. With sample 2 I get 914 kcd.
I enter:
290 cd/mm² (or 315 for sample 2)
note: for a Lambertian emitter, 969 lm / 1.0609 mm² / π = 290 cd/mm²
50 mm lens diameter
correct the Wavien collar multiplier to what you actually got (from 1.19 to 0.88)
note that 1.19 is based on an old test of XP-G2. Osrams respond worse to a collar. Enderman got .887 from CSLNM1.TG, so here you’re right on the spot.
So…your results are OK, it’s hard to tell whether you can improve on that.
Your numbers are fine, it shows that your build is well-done . Indeed these Osrams do not give same multiplication of a collar that a XP-G2 gives (perhaps because of the shiny finish).
At low currents Enderman reached a multiplier of 1.07. So there’s some saturation going on at high current.
But at low it’s still less than 1.19. I don’t know the reason.
ADDED: at 5A the factor was 0.96 so a little better than likevvii’s.
I had put in an intensity of (500cd/mm²) because I assumed that the RLT collar would bring it up near there. Just to be sure I am doing it correctly; I need to set the intensity to ~280cd/mm²? Even though the RLT collar would increase it, I need to leave it alone and have the RLT collar multiplier take care of the multiplication?
After changing:
Intensity: 500cd/mm² to 280cd/mm²
RLT collar multiplier: 1.19 to 0.88
I get: 904Kcd! This is much closer to my recorded data.
Could you verify if my settings are changed correctly?
I see, I had been playing around with that calculator for over a period of weeks. I messed around with all kinds of values. I just realized I had changed the: Lens clear aperture CA (%) from 0.90 to 0.95 because I had an AR coating. My values match yours now.
For those who messaged me about mounting the lens, I have the link to the album below. I used 3D printed parts to seat the lens perfectly focused. After screwing on the head, the lens would be very secured and unable to move. I was able to adjust the RLT collar easily because the lens comes off very easily. However, it took about 14 iterations of 3D prints before I got the right fitment and focus.
I really want to reach 1Mcd with the convoy L2 host. The best thing about the L2 is that it is very compact and the cooling is great because the entire head is the pill. The convoy L2 allows for a max ~58mm diameter lens. I am in the process of talking to multiple suppliers in China to produce a precision grounded thin double aspherical lens so the convex bulge wouldn’t stick out of the L2 head.
I finally took my Z1 to the local reservoir… I took my MF02 and modded L6 for comparison, among others.
I know the MF02 should be over 400kcd, but to my eye the Z1 with CULNM1 threw better. Of course it was a pencil beam in comparison, but it is quite impressive. One interesting thing I noticed with my Z1 was that I had to “zoom it out” a little to correct the focus on the CULNM1. At night, the visible beam made it quite apparent that the focus was wrong with the head fully unscrewed.
