I really think you should consider the EL wire that ImA4Wheelr suggested. I don’t know how long the batteries last but you will not miss it in the dark. This model has slow and fast blinky modes.
Anyway, I’m back from the festival.
I tried the glow tape, it didn’t work at all. There was too much light around killing night vision.
When I used a flashlight to charge them - they were visible. But not enough to catch attention of a sober person, let alone a drunk one.
Without chariging they were barely visible when I knew where too look. Useless in that setting.
So…a glow rope would probably work even worse.
I guess it takes some electricity to be visible in such setting.
It’s hard to know, because the brainwaves are totally cut off from the aluminum foil. Well, I guess that answers my question.
Yeah, in your scenario it sounds like you need some low intensity flashing LED modules. You can buy them fairly cheaply from China these days. It’s just that deployment and recovery is tedious, depending upon how many guy lines you’re addressing. But at the same time, it may be too distracting, like some kind of carnival setup (little red flashing lights all over).
How about this? Motion sensor! Set up an LED light to shine onto the area, rigged up with a motion sensor to turn on at just the right time, before an inebriated fellow reaches the stumble point.
Was just thinking… someone could just fidget something together out of a set of LED Christmas lights. Split the 3-wires into a strand of 2 (they “switch tracks” in the middle), and while they’ll all be in series, a cheap circuit that just dumps a quick HV pulse through ’em every few seconds would be enough, and the battery would last a loooooooong time.
I hate blinkies in general so they are not really for me…
I will surely try reflective rope. I already purchased it and it covers 70% of those passing by if not more.
For the rest? I still like throwies.
But I’m also thinking about ordinary solar lawn lights, $1.2 a piece and should do the trick. I paid more for lightweight pegs recently. And the fact that they are NOT fancy is nice.
Still thanks for the suggestions. I love this forum.
I have also wanted to mark my tent’s guy lines. I have used HGV contour markings adhesive tape. It is sold in form of wide tape or 5cm squares, with different versions for rigid surfaces and tarpaulin. I have used squared one for tarpaulin, cut in half and attached to guy line.
I haven’t thought about that.
Quick estimation:
My large tent (the one that matters) has 10 guy lines. Say 15m total length.
Cut a 20m string into sections, wire together to a single USB plug, add some resistor to reduce output….sounds like an interesting solution.
More involved than I’m willing to do now but I’ll keep that in mind for later. Thank you for this hint.
As to strings themselves - Ali is still cheaper than even these deals (and for me - much easier as well). My recent purchase was a 20m remotely controlled string for $3.64
Yeah, quick search gave me 100 pcs for $8 shipped. But it’s about the waste rather than price.
Something that can be recharged and used over and over seems just better.
Wellp, those doodads also come in usb-powered, not just AA. I usually go by LED-count. So 600 LEDs (2×300) cost me something like 13bux.
Difference is that I got these in like 4 days (non-prime), not 4 months.
And the controllers not only let you do fades, blinks, etc., but you can also throttle down the brightness, too. So on minimum, you should still be able to see the lines quite clearly in the dark, and get decent battery life.
And being that they’re 3×AA or 4.5V, I imagine they might work with a Li cell (haven’t tried it yet, though).
I bought my first tent for the Pol’and’Rock festival (named “Woodstock” back then). It was the cheapest tent from Decathlon that I meant as a throw-away item, I didn’t mean to take it back. I chose a reasonable brand because I wanted some waterproofing. But it fared so well that I took it home and used for a few trips. I used to call it my studio apartment.
Later I grew to desire more space. I purchased a Fjorn Nansen Bastia 3. It was a great combination of comfort, low weight, ease of setup and price. It is not self-standing, needs some nails. It came with 8 guy lines and 20 nails (plus spare). I removed all the guy lines and usually used just 5 nails. 4 was minimum, sometimes I would use up to 8 (bad weather + several days). So it had the same footprint as a freestanding tent…and I indeed had few troubles with people stomping on it. But not zero.
Most of my camping trips have been with it. I call it a 2-room apartment (in polish: M2).
But as I grew older I desired something with standing height. And so I got a villa…and started worrying more about drunks. For a large tent this one is quite simple and easy to set up (but still not as quick as I hoped for, definitely no good for 1-night stands). And it really needs to be well attached to the ground.
Yes, I can take the smaller tent but I’d rather have the comfort of the larger one.
Interesting.
I have USB ones only, it’s quite inefficient to boost power to 5V only to have the lights use resistors to bring it down. And also I lack a powerful enough powerbank, direct connection is better in this regard. This battery box variant may be nice…but I need to figure out some reasonable 18650 / 21700 box. Maybe some cheap plastic powerbank with electronics replaced….
300 LED per string from DC power? I fail to see any source for this in China, the longest I see is 20m / 200 LED. Could you please share a link? Maybe it will help me find them…
