Thanks. That explains a couple things which weren’t clear in the auto-translated version.
It looks like the English manual doesn’t even mention how to calibrate the temperature sensor though. I recall the Meteor had the same issue, so its thermal settings were basically random with ~25 C difference between individual lights. That part of the UI should probably be documented in a more visible place.
Me too. Especially how it compares to a D4. I gotta say, tho, those aux LEDs in the V2 are pretty tempting for a light that’s $3 less expensive, and 8mm shorter.
I’m interested in what advantages the Unicorn has. It’s kinda purty.
From their respective websites (lenght must be Chinese and Russian for length):
I’m interested so see if the 1mm difference in diameter is real and significant.
And, yeah, the less aggressively driven Unicorn does make it more muggle-friendly and appealing to me. Maybe it won’t need to be physically locked for pocket carry.
The total throw on turbo might be similar to a D4, but only because the D4 uses a lot more power. The candelas per lumen should be much higher on the Unicorn, allowing it to throw farther when the lumen levels are the same. In other words, it’ll probably have a much narrower hotspot.
Not sure what the exact cd/lm value will be, but usually I find that the ideal range for EDC purposes is about 5 to 10 cd/lm. The D4 generally gets about 3 to 5 cd/lm, so it’s slightly more floody than I’d like.
I hear the FW1A is moving along too, which has a similar purpose… but it uses a reflector instead of a TIR optic. And with XP-L HI, it’ll probably be even more throwy, like perhaps 10 to 15 cd/lm.
Very very interested with this one. so far three YLPs already in the cart. I hope it uses an efficient buck driver and has flat runtime unlike Folomov 18650.
+1 YLP for sensible max output with thermal regulation.
And pleaseeeeee, NO FET driver for this one.
If I understand correctly, it’s a linear FET. As INFERION said in the Unicorn thread, “Initially, there was an impulse (boost). YAL will have a linear (without PWM).” So it was originally going to use a boost driver, but was changed to a linear FET. The firmware’s UI diagram is named Indigo_Linear_UI.png, and he was talking about using an opamp. It’s all there in the thread for anyone who wants the details.
It looks like it’s using an attiny85v in a QFN package, plus a small FET running in linear mode. The FET seems to be a Vishay SiA448DJ. That info is from December though, and may be out of date.
