That bin allows for fairly large negative duv values. I assume Nichia prefers to keep most of the small duv emitters in the sm403 bin for customers who require uniformity, so that should leave sm4070e with lots of rosy emitters.
I didn’t realize before, but Clemence apparently had (now out of stock) those in D240 output and L2 voltage, which are also good bins for each of those specs.
I received my emitters today, I changed the stock xpl of a nitecore tup to a sw45k. I definitely like it, I don’t see any red but slight hint of pink and color rendition is great. Output has been reduced to about half , didn’t realize that was going to happen, The nitecore tup is rated at 1,000 lumens stock and with the sw45k it’s around 500 or so.
Glad you like it! The high r9 is supposed to help with red rendition. You don’t see red in the tint. It should be a little rosy like you said. With the Nichia 219b, you give up lumens for high CRI. Nowadays, I much prefer a beautiful color rendition over a lumen monster. I guess it varies with everyone but for 99.9% of my uses, I usually only need up to 500 lumens. Share some beam shots of the TUP with the new emitter. I’m curious to see the output with that particular reflector.
Hey azhu, posting pictures on this forum has always been a pain for me. If you want send me a message with your email and I will send them to you and you can post them.
Thanks azhu for posting the pictures. The tir optic has a lot of artifacts and really doesn’t do this sw45k justice. I tried to get best picture I could but in real life it’s amazing, the more I use it the more I like it… Iam going to put another sw45k in a Jetbeam jet-st titanium can’t wait!
Looks like MTN got a very good batch of 219C. I wonder if the ones in the FW3A is from the same batch. So far noone tested the 219C on the FW3A. I’m going to order one from Illumn when they get the new colors in and test.
