WTS/GB: NICHIA 219B NVSL219BT-V1 R9080 EMITTERS! sw45k, sw40, sw35, sw30
425 posts / 0 new
SKV89
Last seen: 30 min 15 sec ago
Wow I wish Lumintop would be willing to sell some emitters to us individually like Convoy does.
azhu
azhu's picture
Last seen: 11 hours 31 min ago
Yeah, it’s really hard to find a good bin of the 219c. Besides these on my fw3a, the only other light I have really nice 219c are from my Oveready BOSS.
Need Nichia 219b r9080 Emitters? (。◕‿◕。)
“The Light shines in the darkness, and the darkness did not comprehend it.” John 1:5
clemence
clemence's picture
Last seen: 2 days 22 hours ago
Hi Azhu, just curious here when did you get this Oveready BOSS? Or when was the approximation date it’s made
Thanks,
Clemence
azhu
azhu's picture
Thanks,
Clemence
It was the very first run of the Raw Ti finish. Ordered back in Jan 2018.
clemence
clemence's picture
Ah, I see. Thanks
azhu
azhu's picture
clemence wrote:
Ah, I see. Thanks
Did you sell these? I think I recall Dan mentioning that he got them from you?
If so and you still have some, I’d be interested in a few Wink
clemence
clemence's picture
azhu wrote:
clemence wrote:
Ah, I see. Thanks
Did you sell these? I think I recall Dan mentioning that he got them from you? If so and you still have some, I’d be interested in a few Wink
Yes he did. Wink
Only few left, all the codes are the same but I have no spectrometer to validate if they’re the same tint.
[Clemence]
azhu
azhu's picture
sw40 on the Lumintop Tool25
staticx57
Last seen: 3 hours 16 min ago
Are those the sm4070e?
azhu
azhu's picture
No, this is the Nichia NVSL219BT-V1 sw40 D220 L2 R9080
staticx57
Sorry, meant to address Clemence on the topic of 219c. The ‘e’ is a special bin similar to ‘k’. Be nice if they were offered for sale by whomever Wink
azhu
azhu's picture
Ah, I believe those are the sm403.
jon_slider
jon_slider's picture
Last seen: 8 hours 28 min ago
afaik
sm403 is N219c 4000k 3 step MacAdams elipse (relatively close to the BBL and usually above the BBL)
sm407e is a very pink 219c, guaranteed to be below the BBL
(I hope someone posts the chart, I cant find it atm)
sw45 is an N219b 4500k, that is not usually as pink as the sw45k
here is an excellent post with more pictures
sw45k is an 219b 4500k, and is supposed to always be significantly below the BBL
the sw45k and sm407e are similar in that they are both below the BBL, and have magenta (pink), tint
btw, A lot of people mis use the word Tint when they mean Color Temperature
they will say, I like Neutral Tint, I dont like Cool White
this is wrong language!
They mean, I like Neutral White CCT, I dont like Cool White
Neutral Tint is not the same as Neutral Color Temperature
Neutral Tint is tint that is not green and not magenta, it means Tint that lands on the BBL
"High CRI lights for sale":http://budgetlightforum.com/node/72660
iamlucky13
Last seen: 8 min 27 sec ago
jon_slider wrote:
sm407e is a very pink 219c, guaranteed to be below the BBL (I hope someone posts the chart, I cant find it atm)
See here from Clemence’s site:
That bin allows for fairly large negative duv values. I assume Nichia prefers to keep most of the small duv emitters in the sm403 bin for customers who require uniformity, so that should leave sm4070e with lots of rosy emitters.
I didn’t realize before, but Clemence apparently had (now out of stock) those in D240 output and L2 voltage, which are also good bins for each of those specs.
staticx57
Andy, group buy for these too? Big Smile
jon_slider
iamlucky13 wrote:
Very helpful!
Andy was correct when he said 403 (is the yellow wedge actually 4030e?),
along w 4050e and 4070e, they are all below bbl
alberto7
Last seen: 2 days 9 hours ago
+1
Lund1660
Last seen: 1 month 58 min ago
I received my emitters today, I changed the stock xpl of a nitecore tup to a sw45k. I definitely like it, I don’t see any red but slight hint of pink and color rendition is great. Output has been reduced to about half , didn’t realize that was going to happen, The nitecore tup is rated at 1,000 lumens stock and with the sw45k it’s around 500 or so.
azhu
azhu's picture
Glad you like it! The high r9 is supposed to help with red rendition. You don’t see red in the tint. It should be a little rosy like you said. With the Nichia 219b, you give up lumens for high CRI. Nowadays, I much prefer a beautiful color rendition over a lumen monster. I guess it varies with everyone but for 99.9% of my uses, I usually only need up to 500 lumens. Share some beam shots of the TUP with the new emitter. I’m curious to see the output with that particular reflector.
azhu
azhu's picture
Let me see if this is possible Smile
contactcr
Last seen: 5 hours 17 min ago
For some reason during the past year everyone gives 219C such a bad rap. Here’s one of my first ever builds:
Purchased from MTN Jan 2018:
219C D240 4000K 90+ CRI
Turbo to Low on a FET+1 10507 uncoated lens
CCT = 4057K (Duv -0.0007)
CCT = 4069K (Duv 0.0011)
CCT = 4006K (Duv -0.0004)
CCT = 3988K (Duv -0.0011)
CCT = 3995K (Duv -0.0011)
I can’t explain the weird Duv spike in the middle. Maybe driver related?
azhu
azhu's picture
That’s pretty solid! I’ve had mixed feelings on most of the 219c I’ve received so maybe it’s just a wide variation in production bins?
Lund1660
Hey azhu, posting pictures on this forum has always been a pain for me. If you want send me a message with your email and I will send them to you and you can post them.
contactcr
This brings up another point. Why dont the big 3 parts companies sell any Nichia? Does Cree forbid it or something?
azhu
azhu's picture
Lund1660
Thanks azhu for posting the pictures. The tir optic has a lot of artifacts and really doesn’t do this sw45k justice. I tried to get best picture I could but in real life it’s amazing, the more I use it the more I like it.. Iam going to put another sw45k in a Jetbeam jet-st titanium can’t wait!
SKV89
Looks like MTN got a very good batch of 219C. I wonder if the ones in the FW3A is from the same batch. So far noone tested the 219C on the FW3A. I’m going to order one from Illumn when they get the new colors in and test.
dotBLF
Last seen: 1 week 10 hours ago
In for 10X sw27!
id30209
id30209's picture
Last seen: 15 min 3 sec ago
Andy can you please edit my request for sw27 to 10 instead of 5?
Thx
WTB Titanium 4sevens 2xAA tube
azhu
azhu's picture
Thx
Done. Thanks for helping us get that much closer to possibly making this happen Smile
