In the Amazon sale ad, I see the orange 4800 5000ma battery has changed to a white 26650 with Wurrkos brand label. Hope its as good as the already tested orange one. Prolly is.
I was expecting a smaller light but am happy it was larger than expected. The specs in the ad are wrong. It’s @ 37mm at the head. 29mm at the tube and 33mm at the tail.
The length is 4 & 7/16 inches. (Can’t find my long caliper duhhh)
Parasitic drain measures 31uA and so not bad, so it will take 19 years to flatten the 5AH battery if the battery itself has no leakage.
I also purchased the 365nm SST-10-UV-A130-E365-00 from DigiKey but I can’t figure out how to get the thing opened to swap it out. Has anyone opened or x-rayed theirs?
I used a heat gun to bring the front bezel ring up to about 60 Celsius but it still didn’t budge. If it’s expoxy then it may need go hotter, or maybe it pops of instead of unscrews but I’ve not been around any x-ray machines last little while so dunno.
