I’ve bought a lot of knives off of AliExpress, quite a few have not flipped well until I’ve cleaned them. I take them apart an clean the bearings with brake cleaner then assemble with a little sewing machine oil or Finish Line fluorinated grease, and boy do they flip a lot smoother and faster! HFT purple threadlocker works great on the screws and pivot too!
The best flipper out of the box I received was a two sun knife from Ali, but it was a little more expensive at $45.
RC if you can get the grease out of the pivot and replace with oil it will work much better. I wasn’t able to open the torx screws in the handle do to strong loctite that wrecked my bits, so if you go that route you may need to heat them first, but I was able to get the grease out with some cleaning with regular printer paper on either side of blade, and tissues.
Also not sure if you are trying to push the flipper towards pivot or using light switch motion, not saying both wont work but second one is better for this model, and if your fingers are on frame lock it can slow the opening as well.
This is my first Ganzo. It won’t be my last. I’m very impressed with the quality. The Firebird FH21 is a very smooth flipper. It is as quick or quicker than my spring assisted Kershaw Blur. It is razor sharp and beautifully finished. It is quite a bargain for $24.99.
Figured I’d give it a shot. It’s listed on amazon for $29.19. Was trying to offer something to compensate your learning curve in the knife. At this point, you spent the money. I just offered to give some back lol. Prime will have me one here by Saturday and includes warranty.
The Ruike is arguably the best flipper available sub 50$ maybe it’s your technique? try “push buttoning” it instead of “light switching” or the other way around.
That said, most of the budget Chinese knives seem to get assembled in the same place they do the milling/grinding which makes them a little gritty sometime, not use the best lube (though IMO Ruike uses the best stock lube)
You’re kinda doing yourself a disservice by not disassembling, cleaning, lubing and tuning the knives. for 99% of the ones i receive the first thing i do is disassemble and even some of the worst stock action tends to get smooth and reliable (the only ones i haven’t disassembled are any of my Sanrenmu 710’s - a SRM 910 g10 version, the steel version needed a clean - Ruike p121, which after a year still feels like a Sebenza - and a Real Steel Griffin Titan, but that’s an entirely different price point (made by the same people as Sanrenmu)
My most recent one was a 940 clone (was really cheap, testing the ergonomics - not for big hands) came super stiff, took it apart, polished the washers on my strop (they were punched and had a slight burr) lubed with thick fishing reel lube and now the action is nearly indistinguishable from a real BM, took maybe 10 minutes.
Also took the left (looking from the spine) omega spring out which made it a lot more fidgety.
Saw this Ruike 801P on YouTube and did some research. I didn’t know that it is a Canadian Company near Vancouver. Just a quick ferry ride to Bowen Island. Maybe I can make a day trip and spend sometime on the island.
The local brick & mortar/online store sells the black stonewash for $34.30 usd and the stone wash for $29.20 usd.
Raccoon, I think you are going about this all wrong. I got into knifes more in depth recently too, but had a Tac force for ages (look on amazon). After getting into it more recently I’ve learned that you actually need to have some dexterity developed to open knifes the way they are designed to be opened. Yes there is such a thing, not even talking about flicking your wrist. I only know so because my cheap knife to >$100 knife all can open fast and quick in my hands using different styles. I’ve only learned this possibility recently, and further started to “adjust” knifes and also lubing them. It is a lot of fun. And I don’t know if I would ever discover any of this if I expected every cheap knife to magically open fast and not even knowing the nuances of opening style.
It’s hard to describe the dexterity bits with your fingers unless you watch tons of video or have someone just show you in person. Even a flipper can be used wrong surprisingly. Many pull the flipper, but you can also press “IN” the flipper, and depending on the knife it makes a difference.
Most cheap knifes can perform well, especially in trained hands and or with some “tuning”. But expensive knifes will probably open fast by someone that don’t even know what they are doing.
Non-assisted flippers tend to have their own character. It’s a matter of geometry, detent, and action. Some knives work better with the “light switch” method of flicking the tab downward. Some work better with “push button”, where you press your finger into the tab to build tension and then break it with a slight downward shift. Some knives work well with both but all tend to have their own particular feel. This isn’t a feature of price or quality in my experience. What you should get from a higher end knife (in addition to nicer materials, better steel, workmanship, QC, etc.) is a better flipping experience overall.
That said, you should never need wrist action for a flipper knife. You should be able to “flip” or “snap” the knife open with the movement of one finger alone. If you can’t, and you’ve tried different techniques, then the knife either needs work or was poor quality in the first place.
So now that you’ve gotten into it a little, what knife has given you the best flipping experience? Which one makes you smile every time you snap it open?
