I think they’re just distracting, especially racoon’s creepy sig picture. If it was small, maybe not so much. And really, what do big unrelated sig pictures add? At best, it makes the forum look like it’s filled with advertising.
I’ll look into an ad-blocker. Do you recommend one for Chrome? Ad block plus, maybe? Can it remove just racoon’s sig, and not mess anything else up? Nobody else’s sig bothers me in the least, so I don’t want to block anything else.
See the bottom one? That spec of whatever can cause it to look like the top left one after a few seconds of turbo. That is the worst solder job I have ever seen. The wires, the LEDs, the solder balls, the flux. It’s all bad.
No, they look the same , the only difference is ,the black wire is now desoldered, probly because it got even hotter because the bezel wasn’t pushing down & aiding heat transfer ,
I could smell the burning plastic before I opened it , that’s the reason I opened it.
Some people’s complained that it was to easy to accidentally activate,
Lumentop changed the button to make it activate easier ,
I think the two are related.
Good God can’t we all just get along? If you see something you don’t like, just ignore it and move on. Some people need to learn to not be so damn sensitive and stop the constant complaining about others comments or postings. It’s just words and pictures, no way can they physically hurt you. You only let them hurt you feelings because you’re just too sensitive for the internet.
That being said and back on topic, I just ordered my FW3Ti polished XPL!
