Reading the description of the JC FW3A it looks like the secondaries work like on the Dragon: it will ramp up the secondaries, then switch to the primaries. I think that’s possible with a different hardware modification (it will involve cutting the trace to the Nx7135s, jumpering them to ground to disable them, then attaching the aux LEDs to pin 6), and some Anduril modifications (new brightness ramps). The aux LED brightness would not be regulated, so they would dim as the battery drains. Likewise, you’ll need to sacrifice the Nx7135 channel, which means mid-to-high modes will be less efficient, and drain as the battery drains. If you’re OK with that, I think what you want is possible with the FW3A driver and Anduril. I can help but I don’t have the time to try it myself to verify it before you jump in.
treellama, it looks like you know your way around the driver board and thank you very much for taking an interest. I do not pretend to understand everything you have written, but it looks to me that getting the FW3A driver to work with secondaries will come at a significant cost against the normal functionality of the light. Since that seems to be the choice, I believe I will choose to leave the light as is.
If another option arises in the future, such as a different mod, an updated driver, a spacer-pill device that will allow the use of a dragon driver in the FW3A host, I will definitely be interested. But crippling the light (by lowering its efficiency and having no regulation) to add fancy secondaries is not something I would prefer.
Google’s Android is a good example.
Android was, is and will be open source.
But Google built many ‘hooks’ in Android that link to propetary software.
But my guess is that’s not the case with the driver software. Making a change to open source software doesn’t make it yours or give you some sort of control over it. It may become a fork, but stays public.
The Dragon driver doesn’t have a Nx7135 channel either; I’m not aware of a light with secondaries or aux LEDs that does. The D4v2 doesn’t, for instance. So, you may be holding out for a unicorn!
Now, it gets more complicated if he’s complying by providing source through a written offer. You can read the other FAQs there, but I’m giving him the benefit of the doubt that he’s providing source code along with his lights.
Well, all this talk about forcing the FW3A to take on aux LED’s… and I just got my GITD insert. Standard Green. VERY bright! I couldn’t get over how strong it is for the first 5 mins. Can even use as a moonlight mode. The GITD insert hangs on for a very long time as it wanes. Great step up from GITD tape on the inside wall. Still thinking I may give tritium vials a try. Drill in some grooves across the GITD insert. The way it fits under the optic, there’s quite a bit of clearance so you wouldn’t need to drill deep enough to submerge the entire vial thickness.
Lexel board with green and pink led's, LDO and voltage monitor removed, 2kohm resistor.
High is still a bit bright but low is perfect and an added bonus is how it flashes one time low then the next high and so on (Idk if this is by design or not but it's cool as hell!)
Finally fixed my FW3A driver and added my Lexel Aux Board. I needed to replace the ATtiny85 chip after an unsuccessful flash. Thanks contactcr for the assistance! I was able to flash the chip by itself and then re-flow it onto the driver.
The Blue/Green one is on all the time
The “Fire” one can be on, off, or blinking.
Much like the Astrolux S43 has 18350 and 18650 tubes, I would also like to have an 18350 tube for the FW3A. Sometimes that little extra savings in length can make a nice difference. It’s a HUGE difference on the S43.
Yep 18500 fit…… now the 18350 fits with a longer tail cap spring or stretch the stock spring… small as I could go with out getting into the taper of the body…
