Yepā¦ that just about sums it up. :person_facepalming:
As we discussed a few days agoā¦. in most cases it is a very bad idea for a manufacture to base changes to a product on idle forum chatterā¦ā¦ especially chatter that is nothing more than subjective opinion.
Got something that worksā¦. leave it alone. :+1:
Please point something out to a thicko like me , whatās the difference between party strobe & tactical strobe ? To me they are the same & the only difference is the tactical strobe is brighter , am I missing something?
Usually Tactical strobe alternates between 2 different rates, but on the FW3A Tactical seems to have a longer On pulse which is more irritating plus it is brighter. Party strobe has a short On pulse that can make things seem to move in slow motion and is not irritating.
I remember because I repeat myself a lot. I say how to do a factory reset pretty often.
Factory Reset
With light turned On, click 4 times to enter ramp config mode. At the prompts (fluttering light), respectively, click 1 time, then 21 times. If there is a 3rd prompt, click 7 times (this is seen when in stepped ramping mode).
My FW3A from the first batch died last night. I was using it at work (at pretty low power, below 350mA) and all the sudden it got stuck on, I could go above 350mA but now below.
I took it apart today and found one of the 7135ās completely shorted between output and GND (I did have to strip them all to find that).
Got it going again with another 7135 but I think for many thatās above the level theyād be able to diagnose / repair.
Not upset in the least, I jumped on the fw3a train from the beginning, I knew going in there could be problems early on. Whatās odd is all the soldering looked great, no bridges or solder balls or anything that stood out, no excess flux, nothingā¦ That one bad 7135 seemed to die internally with nothing triggering the failure other than use/time.
Again not a complaint, donāt even plan to contact Neal, just reporting here. Allās well again.
