Does this light exist ?
1x18650 (or 21700)
Floody
Warm led
Few modes programmable to avoid high current modes (ideally can be configured to not go above around 200 lumens) and blinkies.
USB or magnetic charging (not mandatory)
Affordable
Thanks guys :+1:
Suggestion: [New + Review] YLP Unicorn 1.0 (1x18650, LH351D, backlit side switch, magnetic tail, TIR lens, ramping)
You can make ( or ask Simon to make for you) a Convoy S2+(18650) or an S21 (21700) with these specifications.
A 3000k sst-20 (or other warm) led.
A biscotti driver.
And as many 7135 on the driver as you like. (maybe 3 or 4)
And a 60 degree floody tir optic.
I don’t know if all these components are available for the S21 but they are @ Convoy ali store for the S2+.
Thanks, i figured the S2+ was the closest to what i wished, i had some on my Aliexpress basket.
Is there anything like that with in light charging ? (USB or magnetic ?)
EagleEye X2R.
Basically an S2+ with USB charging.
3 modes, higher at about 1,6A but the low is a bit too high for me.
Direct swap from the stock reflector to 20mm standard TIR (Yajiamei for example)
Anyway, cheap and perfect for muggles.
Skilhunt has some models with magnetic charging i believe
