I would like to check those out, I didn’t have any luck with finding them though.
My only concerns would be if they have good CRI and what the price is.
yes
for me 3500k is too yellow/orange during the day when Im indoors by a north window.
I like 3500k in the evening
during the day I EDC 4500k
my house lights are 3000k
I tried 6500k over a soldering station, but found I prefer 5600k
if I had to pick just one cct for everything
day and night,
working and relaxing,
it would be 4500k
but those are 4 different scenarios and I have 4 different CCTs for that
Thank you very much. That’s a lot of useful information. I plan to use my quad as an EDC that’s why I am uncertain what CCT I should choose. Maukka’s measurements also add to my doubts, because diodes seem to have lower CCT than it is claimed by the manufacturer and 3500k tends to have the highest CRI overall. (Btw, could somebody explain why?).
LEDs vary within a range of ± 250 cct when they get grouped into CCT bins
I do not believe that it is accurate to say that 3500k has the highest CRI, I cannot verify that information based on the info you have provided.
if you plan to EDC during the day, I would choose 4500k, or even 5000k… some people even prefer 5700k…
but if you keep your question simple, such as is 3500k or 4500k more useful for daytime EDC, I would definitely not suggest the 3500k
3500k is quite warm during the day
it is imo a specialty CCT, for relaxing in the evening
In the case of room lighting though, it will always be up-mixed with sunlight. So the lighting might be 3500K, but the effective CCT will be closer to 5000K. If 6500K sunlight is half the total.
That makes no sense in regard to my comment about an edc flashlight
Well the purpose was to discuss how ambient light affects the final CCT.
Alright, here’s that comparison I talked about. The camera was in full manual mode, and the only setting changed for the second picture was to shorten the exposure time because the (8) E21’s were obviously brighter than the single 219B
I probably should have changed the camera’s white balance too, but it remained constant at 4000K. This isn’t very scientific, but it’s interesting none the less.
Nichia 219B NVSL219BT-V1 R9080 4000K (from Azhu’s WTS)
Nichia NVSWE21AT 5000K CCT & Bins:sm503-D240-M1-R9080 (From Virence)
That is not correct
Ambient light does not change a flashlight’s final output.
OP updated with these:
Edited version for better viewing. The processes goes like below:
- Partially cropped near the lower left center from the cross
- Gaussian blurred twice
- Exposure of each shots adjusted to match nearby shots
[Clemence]
Cool chart Clemence! Thanks for sharing.
Thanks for the chart. It really helps to sort things out. I know this is offtopic here, but please bear with me. On your web site you suggest using Pb63Sn37 solder paste, could I use Sn63Pb37 or Sn62Pb36Ag2 instead, and what are the drawbacks?
I haven’t done any testing myself, my opinion is solely based on maukka’s testing on the page 2 of this topic.
Thanks for sharing your experience.
Pb63Sn37 is a totally different alloy to Sn63Pb37. If I wrote that, that must be typing error. Please check this thread: [Reference] Physical and Mechanical Properties of Solder Alloys
Sn63Pb37 is very popular because it has many good characteristics: low melting temp, eutectic, superior wetting, good thermal and electrical conductivity, ductile, very good joint quality, and cheap. I strongly suggest this for soldering E17A or E21A if you don’t have better alternatives. Because it has low melting point and excellent wetting. This is very important for arrayed configuration when you need to clean the flux residue thoroughly. Higher temp will make flux residue gunk harder to clean. Without proper cleaning, the gunk will stay beneath the LED and later when the LED warmed, it will thin, capillary seeps out, and gets burnt.
I on the other hand prefer fluxless reflow soldering (with nitrogen gas) or use water based flux. It’s so much easier for me.
[Clemence]
Thanks for the detailed answer, I think a lot of people here will find it useful. Regarding Pb63Sn37, it is indeed written on your site to use this soldering paste for manual reflow. My fist thought was that it is a rather strange choice for soldering alloy, but I assumed that you know best, and tried to follow the instructions on your site. In your videos where you are showing a reflow process for E21A are you using water based flux? Have you tried removing it without ultrasound bath? Currently I have only fluxes that can be removed by some kind of solvent(usually I am using isopropyl alcohol), will isopropanol washing damage the led?
Without ultrasonic cleaner, the only way to properly clean the residue is to heat the module to 80C (on hot plate), let the gunk thins and flows - soak in hot IPA bath, brush it - reheat to 80C - resoak - rebrush - etc….until you don’t see any flux residue coming out when you warm the module.
Unless you want to run it hard, simple brushing in hot IPA is enough. I did super clean cleaning for VR21SP4 because it has narrower gaps at only 0,25mm. In full power hot run, without proper cleaning the flux will “climbs” to the phosphor layer. With VR16SP4, the gap is 0,4mm and won’t cause too much problem. With crowded E21A arrays, anything closer to 2A/LED requires meticulous soldering and post cleaning.
This is my first attempt with gapless design. Check the bottom picture
[Clemence]
Yes, if you want to show the colors differences better, the camera needs to be calibrated on a same (true) white point for each different light CCT before shooting the picture, or you can put a true white chart in the corner of the picture and correct the white point afterward.
The 219B SW45K has a bit more chroma and hue shifts than the E21A which has better colors fidelity.
I guess that the 219B is saturating the wood colors to make it looks a bit warmer than in reality. I better trust the E21A despite its cooler aspects, the wood probably has those palish/grey-ish colors, being discolored by sun’s UV.
Jeez, I never thought that soldering E21A will be this complicated. I guess I have to buy ultrasonic cleaner then. In the description under your video(“Easy Nichia E21A soldering on Virence VR16SP4 MCPCB (Part. 1)”) you mention that you heat MCPCB until E21A gets stuck to the pads then cool it and after that you add more flux(on the E21As?) and reheat it to finalize the soldering. Is this two step process really needed? Can I just wet the pads with the soldering alloy add some flux place E21 and heat it till it is soldered? Or do I need to add more flux after that and reheat it? Won’t zinc chloride damage the led surface?
P.S. Thank you very much.
Why not just buy it presoldered from Clemence? I bought a bunch of E21A already on board so don’t have to deal with any of the headache.
I would gladly buy a presoldered one from Clemence or anybody else if I could. But the MCPCB that I need - VR16SP4 is out of stock and probably will be out of stock for a long time.
