Nealsgadgets. It is not listed but if you ask Neal he may get you one.
Anyone have throw numbers and/or beamshots with a dome on XP-L or even XM-L2? Looking for a further throwing “walk around” light (and willing to sacrifice throw to loose the pensil beam it has now with the SST-20).
The form factor is ideal [to me] for camping / hunting / hiking in heavily wooded area but the tight spot and minimal spill make it not good for that. I’d rather it be a usable light than a shelved mini thrower.
Second the motion on the LH351D, they trend towards a larger hot spot that looks clean, artifact free, and work great in a light like this! I like the 70 CRI W6 at 5000 K, it’s a soft white high powered emitter that never fails to impress me even ( or especially) in the lowest modes.
I actually just got done doing exactly that, went with a W6. It’s better, will definitely be more usable but still not what I was hoping for…
If I could get the same beam shape (albeit a lot less reach) as my FT03 that’d make it perfect. It’s [the FT03] hot spot to spill ratio is just perfect for the heavily wooded areas I frequently camp in but it’s to large to take on minimal backpacking trips and I don’t need quite that much lux 99% of the time.
I wish there was any 5050 led with a better tint (xm-L2 or SST-40 or 3v XHP50.2) and without the yellow corona and/or power ralated tint shift! Still, it’s WAY better for my needs than the CW sst-20 it had (back when I was going for pure performance / numbers)
Well, since you already have the floodiest 3535 3V LED, the other option would be to replace the smooth reflector with an OP reflector.
Problem being that we don’t have any measurements for the reflector.
Getlemen, I gotta say thanks to both of you for the recommendation yesterday! I wasn’t very impressed with it at 5m in my basement, sure it was better than the SST-20 but I didn’t think it’d be what I wanted IRL but when I took it out to the woods last night man did it change my mind. This is the light I needed for my use!
Glad we could help.
How do you remove the driver?
Carefully. It’s glued in, so you need to remove the mcpcb and then tap it out with a tool through the 2 wire holes. There is a chance you could press down and break a component on the driver damaging it.
I have not removed this particular driver, but I have removed similar glued drivers from Lumintop and other brands. Maybe someone that has removed this specific one can chime in and give more exact instructions.
First, does it have to be a mini? It’s kinda ruining what makes it “special”.
The C8’s about the same size, and easier to mod. Lotta other lights, too.
Second, stick-on diffusion film would give you what you want, and be 100% reversible by simply peeling it off.
If I’m ruining a product I own by making it better suited for my needs so be it.
I like the C8, I have 2, it doesn’t provide the beam I was after. The GT mini has better proportions for my hand (shorter, more comfy to cary), it doesn’t force me to hold it like a tactical light because of the side button, also because of the side button it runs Anduril giving me a infinite ramping interface and battery check and more fun modes for around the campfire (which it can also simulate lol) and IMO looks better then any C8.
Your second point is a good option I hadn’t considered on such a light (I have DC-fix on several smaller lights) and would probably work just as well but I had previously built the light just for numbers using a CW SST-20 (like way over 6000k) and needed to do an led swap to make it usable at all again and the end result was just perfect for me so I doubt I’ll be making any more changes on it now.
Yeah, I prefer the GT Mini in general.
Better overall design, better heat dissapation, better stock spring setup(BeCu driver and dual steel on the tailcap), and more throw at the same power level.
The only thing I would change would be to make it into a super thrower with an SST-20 5000k 70CRI, or a balanced thrower with an LH351D 90CRI.
Where’s the best place to get dogfarts these days? I could be tempted to mod a balanced thrower.
So I made new holes to fit L4Ps 3030 white flat board…but now the switch comes in the way of one of the screws. I was thinking of using the original screw holes and making new ones for he wires which is what I should’ve done first but I kinda messed them up so the screws just fall out. I guess I could find new screws that fit.
The main purpose of the screws is anti-rotation while you’re assembling it, pressure from the reflector holds the mcpcb down onto the shelf well already. As long as the l4p board is the same thickness as the original you should be absolutely fine with just one screw.
Arrow has them but now that they don’t do their free shipping anymore there may be a better, Europe based seller for you.
So the new driver doesn’t fit…it’s just loose. Do I need some kind of glue to hold it in place? Also I noticed that the wires are a tiny bit thinner and one of the components is different. I think it’s the FET.
