Yet another aspheric thrower
34 posts / 0 new
Enderman
Enderman's picture
Last seen: 1 hour 24 min ago
Decided to make a more portable/compact optofire using the short focal length A037 lens I had.
Parts:
Osram CULNM1.TG 1mm^2 LED
3S 6A mountain electronics buck driver
32mm wavien collar
120mm A037 Optolife aspheric lens
Copper heatsink and 80mm noctua fan
External battery (soon to be replaced by 3×18650 internal batteries)
Performance:
Measured at 50m
Lx1330b – 1500 lux
Tasi TA8132 – 1552 lux
Tasi 632A – 1504 lux
1500 lux @ 50m = 3.75Mcd
A bit lower than I had hoped for however the smaller heatsink, small wavien collar, and lens imperfections all contributed to lower performance than the original Optofire.
It also seems like a small portion of the lens around the outside (only a millimeter or two) is not receiving light due to the aperture angle of the collar.
A slightly longer focal length lens or larger collar angle would make use of the full diameter of the lens. This wasn’t a problem with the long focal lenth A380 lens.
The A380 lens also was better at focusing, with less aberrations.
Despite this, the advantage of the thic A037 lens is that all the light coming out of the collar is being collected, about 500 lumens all going into the beam.
The result is a very bright and visible beam Smile
Light engine assembly:
Exterior:
Beamshots:
Video in a large room filled with haze:
Once I have the 18650 battery carriers mounted inside I might consider selling this light Smile
Enderman
Enderman's picture
flightless22 wrote:
Nice build. 3.75Mcd is still impressive. Thumbs Up
What was the total cost for such a thing?
A few hundred dollars, maybe close to 400 if you include all the shipping and taxes and stuff.
The most valuable part is the collar which isn’t available to buy anymore, so even though the price for it was only like $75 it’s worth a lot more due to rarity.
pscal
Last seen: 2 days 3 hours ago
Sweet build, and excellent performance!
Enderman
Enderman's picture
Thanks Smile
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 hours 49 min ago
Another awesome Enderman build Thumbs Up
I’m curious to know why you think the smaller heatsink contributes to lower output? I mean it’s fan cooled….
Enderman
Enderman's picture
The LED is being run at its peak, but the higher the temperature it is at the lower the output.
Usually I try to use larger CPU heatsinks, at least ones with heatpipes to move the heat away from the MCPCB faster.
In this build I had to use a low profile server heatsink and low profile fan to keep it compact.
It’s still better than just a passively cooled flashlight body, but not as good as the BXTS13A I used in my previous builds, and far from as good as something like a NH D15 which would be the best possible scenario.
pinkpanda3310
Did you measure the temperature?
Enderman
Enderman's picture
Nope, but it hasn’t burnt up so far so all good Big Smile
Scallywag
Scallywag's picture
Last seen: 2 days 4 hours ago
Someone get this man a LEP Evil
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
DavidEF
DavidEF's picture
Last seen: 1 week 1 day ago
Why? He’s already making lasers from regular LEDs! Shocked
Good job on the build, Enderman!
- The YKK Philosophy
Chatika vas Paus
Last seen: 36 min 31 sec ago
Maybe I’m still too newbie to understand or I just prefer flooders, but…
what is the point of making such flashlights?
Except for fun.
Too large for short distances. And too focused light.
For a long distance illuminates a small point and you need to use a binoculars to see anything.
DavidEF
DavidEF's picture
Except for fun.
There are actually a small minority of BLF’ers that can use a good thrower like this. For the rest, it’s just a toy. I don’t have any use for a thrower, but I’m definitely impressed by the reach of these things. I’m not a flooder either, though. I prefer a medium size hot spot and a decent amount of corona, with very little spill. Some of my favorite lights are TIR.
Enderman
Enderman's picture
I’m working on one!
Thanks! <3
Except for fun.
Yeah mostly for fun, it’s like a fat laser with a very visible beam that isn’t dangerous to the eye and can’t cause fires.
At 1 or 2km the spot is large enough to light up a house, so even though you can’t see very many details from that far away you can still clearly tell that there is a house, without using binoculars.
Your vision is better than you think, look outside, you can still see stuff at 5, 10, 15km away.
Turby3Pots
Turby3Pots's picture
And I might consider buying it Smile
Lightbringer
Lightbringer's picture
Last seen: 50 min 10 sec ago
Well, not yet
And many light-years away. too!
Enderman
Enderman's picture
Shocked Big Smile
Lightbringer wrote:
Well, not yet
hahaha true!
The_Driver
The_Driver's picture
Last seen: 15 hours 31 min ago
Nice!
A flashlight with a Noctua fan...
It would be interesting to see how much relative output the LEDs looses over time due to heating up.
Scallywag
Scallywag's picture
Enderman wrote:
I’m working on one!
You monster. I’ll have to keep my eye out for a build thread Wink
Enderman
Enderman's picture
The_Driver wrote:
Nice!
A flashlight with a Noctua fan…
Ah true, I could take several lux measurements over time.
When I did the intensity measurement I waited a few minutes before taking the final reading.
Scallywag wrote:
Enderman wrote:
I’m working on one!
Wink
Tally-ho
Tally-ho's picture
Last seen: 1 day 18 hours ago
It’s impressive to see what you can do with only 3 screws. Big Smile
Isn’t it this one ? : http://budgetlightforum.com/node/63796
Enderman
Enderman's picture
Yeah I haven’t had time to machine the piece of metal I need to hold and cool the crystal and laser.
Hopefully once school starts in september and i have access to the machine shop again Smile
Sirstinky
Last seen: 2 hours 48 min ago
That’s pretty slick! Like a laser beam!
Enderman
Enderman's picture
Thanks Big Smile
I like fat lasers
Sirstinky
What’s the power output on the led, like volts/amps?
Enderman
Enderman's picture
It’s running at 6A and about 3.7V, so ~22W
With three high capacity 18650s it would run about 1 or 1.5h on max
Sirstinky
That’s a lot of power through that tiny led! Good to see it’s fan cooled.
Rusty Joe
Rusty Joe's picture
Ok now that is ridiculous
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
Enderman
Enderman's picture
It’s not much compared to the 200W that the CFT90 was running at in my syniosbeam build Silly
Big Smile thanks
MRsDNF
MRsDNF's picture
Last seen: 9 hours 35 min ago
You are one crazy dude Enderman.
Keep it up. Smile Beer
Enderman
Enderman's picture
Thank you Big Smile
grin
Last seen: 1 hour 21 min ago
Enderman i have some questions for the throw master. i know that the collar directs the light back onto the led but does depth of field and size of the aperture have anything to do with throw?
Do you think the collars could be made by cutting a hole in one of these Aliexpress with a diamond hole saw?
