We arranged to try new material with said 20% better performance. It’s a beta release, but I took the risk. Sounds like finer and thinner aluminum oxide grain.
Now they’re still finding a facility and vendor where this new process can be done. Usually everything should be done within 2 weeks after order approved. I sent the design about a week ago and still waiting for their next step.
Interesting to hear of an E17A-optimized board in the works. The logic makes sense, and if the E21A continues to be offered, then there’s not loss of existing choices.
Since your site currently lists the E17A’s as out of stock, I assume you’ll be getting more of those. Will that include high CRI versions in multiple color temperatures like you offer for the E21A?
Also, are you planning to stock more of the E21A red, green, blue, and amber emitters?
Thanks! I see the store is already updated with a complete range of high CRI E17A.
Do you know if the E17A would be a better match for the Armytek optics that you have been selling?
I suppose if so, that question would be more relevant for the Tiara, as the Wizard seems like it would have high enough power it should use the E21A quadtrix regardless of how it pairs with the optic.
Armytek optic has 5,5mm aperture size. So a quadtrix E17A should fit with plenty of wiggle room. You’re right, its a better fit for Tiara (3A max). Wizard max current is about 2A. Although I haven’t tested VR16SP4m until they’re made, they should perform well up to 4A. The narrower gap at only 0,1mm will reduce it’s max over current capability for much better beam.
So, will VR16SP4 still be available? Or is it a discontinued product that will be replaced by VR16SP4m?
I agree with you. 4xE17A may be useful when you want to archive a tighter beam with more candelas or in smaller flashlights, but 4xE21A most likely will be brighter and more efficient even with current incompatible optics.
Some numbers from ESTtool(E21A 3500K and E17A 3500K):
I’m quite surprised the E17A is not that far behind the E21A in terms of efficiency. If Clemence will ever make a 13mm board, I will buy a bunch. There’s so many AA/AAA/16340 lights I can think of that can use the 4xE17A
That depends on the current. On lower modes they are indeed very close(about 5% difference), except the fact that E17A has noticeably higher forward voltage, however on higher modes e.g ~700 lm E21A achieves 108 lm per watt while E17A only 93lm per watt and that’s already 16% which is not that small, at least for me, plus again higher forward voltage. Anyway, I’ll wait for the tests before drawing any conclusions.
I will be modding 3 identical hosts with quad e17a virence board, and I can’t decide on which CCT’s to pick.
The max output with these hosts will be about 260 lumens using the e17a 9080 LEDs, with both floody and throwy optics.
I typically enjoy lights from 3000K to 5000K, but have never tried 2700K, and sometimes find 5000K too cool.
Any recommendations?
