i didnt get reply from manufacturer,yet.
i will reply you later
Yokiamy: Yokiamy:Simon, is there an easy method to change or disable the temperature regulation of the L21a SST40 driver (i have the version with 4 modes only) ?
Maybe by disassembling the temperature controller, or soldering a bypass resistor, or just bypassing it with a wire?
Simon, any ideas about this ?
Thank you, looking forward to it !
Anyone tried the SST40 in DA tint yet?
Still waiting for my 5000K DA from Simon and 5000K DD from Kaidomain to be delivered.
Ooo will be interesting to see how those compare
Yeah I’m quietly optimistic… I hope that they will be a lot better than the “regular stuff” they have always sold in the past.
Is it possible, that you fit your 22mm XHP35 Boost-Driver to a 17mm driver board? That would be realy great.
Hi Simon, did you overread my question?
Simon Mao: Yokiamy: Yokiamy:Simon, is there an easy method to change or disable the temperature regulation of the L21a SST40 driver (i have the version with 4 modes only) ?
i will reply you laterThank you, looking forward to it !
Wieselflinkpro:Is it possible, that you fit your 22mm XHP35 Boost-Driver to a 17mm driver board? That would be realy great.
17mm is too small ,friend
Simon is it possible to make XHP35 driver to run on 1S/2S battery and in 20 MM size?
Got an issue with my XHP35 driver in a L21A host with a freshly charged 40T - on 100% mode it will just flash and drop back down to 1% mode instantly. Also makes a high pitched whine sound that gets louder as you go to 10% and 40%.
Any ideas?
Any ideas?
high resistance or low voltage,friend
little small size 20mm
maybe can make xhp35 driver run on 2cells
Hi Simon.
Is it possible, that you fit your 22mm XHP Boost-Driver to a 20mm driver board?
Will the Convoy S3 (I like the design and the lack of pill) appear with thermal control and the choice of XML and SST emitters?
Yeah I also love the S3. I have two custom built ones! I don’t even own an S2/S2+ because of the brass pill, and I won’t even buy the S21A because of that. Integrated shelf tube lights/hosts as well, please Simon?
Hi Simon.
sorry ,only 22mm currently
sst40 and following driver can be installed in S3
i will add a link in my store
Exciting!
