High Amp cells not only give more output but also get more high output usable runtimes, the Samsung 25S beat all those cells mentioned above in terms of output according to lygte-info.dk btw
It is 2S2P on the Mateminco and Astrolux. You have to look at the Driver-Side Batteryboard too.
It has nothing to say that the springs are positioned diagonaly and not next to each other like Haikelite makes it on their 2S2P carriers. For haikelite it is true, you can see the if its 2S2P or 4S1P on the position of the springs.
Can I charge cells that I will use in this light separately? I only have 2 slot chargers. Is there something I should be aware of if I charge the cells 2 at a time?
It does and the 20S is even higher current but the capacity is too small. The P26A I believe is the optimal performance/capacity 18650. It maintains higher voltage over other similar cells for the majority of the discharge curve, which makes it more useful for the entire runtime.
Jason mentioned Molicels might not be readily available. I’m not sure about the rest of the world, but it’s now easily purchasable within the US. Many shops imported the Molicels after Mooch rated them as the best all around 18650 and 21700. Illumn in California stocks them now and ships super fast. Though for the price, the 30Q is still a very good choice and probably one of the easiest to purchase.
P26A and P28A flat heads both work in the MF01S. However, I only have 2 of the P26A so I tried putting 2x P26A and P28A in it and only got 40 lumens more than Sony VTC6. But the VTC6 is already higher power than the Samsung 30Q so still not bad I guess. The P26A makes much more difference in the E07 per my test results above. The VTC6 therefore is also a good choice for the MF01S. I tested it at about average 400mah more capacity than the P26A, 3120mah vs 2720mah despite the P26A is only rated at 2600mah.
Is this directed at me because I said performance was a low priority in my opinion? I will assume it is.
Let me give an example to better illustrate my point. Let’s say you were wanting to buy a high-performance car. Would you buy car A that does 0 to 60 mph in 3.1 seconds or would you buy car B that does 0 to 60 mph in 3.2 seconds?
Keep in mind these are factory ratings and in the real world the acceleration will vary based on driver experience, the road surface, tire temperature, whether there’s a full tank of gas or not, etc.
Would you buy the faster car A even though it cost 20% more, would take an extra six months to be delivered, was not quite as comfortable as the other car all for the bragging rights of being one tenth of a second faster?
It seems kind of silly doesn’t it?
Back to this flashlight, does this mean those interested in maximum performance will be buying the 6500K xp-g3 version because it is the brightest? Maybe, but I have a feeling some may put color temp as more important than max performance.
Is everyone buying the black version because it can shed heat the fastest and have the highest sustainable output? Maybe, but I have the feeling some may put aesthetics as more important than max performance.
When it comes right down to battery choice, does it really matter if one battery gives you 500 more lumen than another battery when you can’t even see it with your eyes? Our eyes probably couldn’t even see the difference between 14k and 15k lumen in side by side lights. The only way you would know which is which is to measure them in an integrating sphere.
I could even make a case that you don’t want maximum performance. In trying to squeeze out every last amp and lumen it’s quite possible you could burn up an led or damage the driver. If you are a skilled modder then it would be no big deal to fix it, but not everyone is a skilled modder.
Anyway, I hope I put some perspective on battery choice. Both Molicel P26A and P28A and 30Q are good choices. I hear the VTC6 tends to loose capacity quickly over time so that would not be a top choice in my opinion, but is probably no big deal. I think Rock will be just fine with his battery choice.
As long as you don’t pull the batteries out early, you should be fine. When batteries are used in parallel, like on the the MF01S, it’s important that the voltages are exactly the same. So let’s say your charger stops at exactly 4.19v. As long as both sets finish their charge, all 4 batteries will be at 4.19 volt and you are fine.
If you let 2 fully charge and pull 2 out early, at say 4.12 volt, then you put the 4.12 volt next to the 4.19 volt you will get a spark and 2 batteries will drain super fast and 2 batteries will charge up super fast as they try to equalize the voltage within a few seconds. This is bad for batteries and a bigger voltage difference may overheat a spring and collapse it. It just depends on how big the voltage difference is. 2 fully charged and 2 drained could be really bad. A difference of 0.01v or 0.02v should be no big deal.
So just let both groups of 2 batteries charge fully and you should be just fine.
Well dang I appreciate all this input and I probably should have mentioned I’m in the US. Honestly I’m ok with losing a few hundred lumens or so for better capacity. Seems to be a tossup between
P26A’s and VTC6’s at the moment and I’m leaning slightly towards the latter if that difference in mAh is significant enough in terms of capacity/runtime
It amazes me that Flat Tops work, because when you look at the contacts closely you’ll notice they are recessed in a tiny white cup. So how are Flat Tops making contact? Probably the basis for Astrolux ’s alert that only button tops should be used with this light.
I’m with JasonWW, in that I’d rather have longer runtime than just a touch more lumens that won’t be readily perceived by the naked eye. Seriously, with this kind of output level, the only time I can imagine someone might want to achieve the absolute maximum possible lumens is if they were going head-to-head against someone else’s flashlight for comparison… and boasting. Useless ego posturing that… has no lasting value at all. Teenaged braggadocio.
Now, output by temperature may be interesting if there’s a notable enough difference. I haven’t watched the video review yet, but is there a notable lumens difference between 4000k and 6500k on the SST20?
Also, how’s the heat management in the MF01S? Can this actually run on turbo for a few mins before becoming too hot to handle?
This was posted earlier. I think Bombay got it from a Chinese review.
I’m not clear on the leds myself. Page one of this thread says it will use SST-20 and XP-G3. I assume the 6500K would be XP-G3 and the other two tints would be the SST-20.
I looked on Banggoods website and there is no mention of XP-G3. It only says SST-20. It’s confusing. They might have changed leds at the last minute.
