Yep 18500 fit…… now the 18350 fits with a longer tail cap spring or stretch the stock spring… small as I could go with out getting into the taper of the body…
No, it works fine with a longer BlueSword spring…2025lm is enough in this little guy…
I thought about cutting into the taper…making it shorter but the same diameter as the straight shank of the stock body… then a sharper angle…re-taper to blend it, but then it would be bare aluminum and I would have to blast and polish it and use it on one of my 2 bare aluminum FW3’s… I wanted to see how it looked as a stock color… maybe on the next one…
Making contact is one thing, shortening the light as much as possible is another. IMHO you have the most awesome FW3A on the planet already but maybe it’s possible to improve it still?
Maybe you could alternatively reduce taper depth?
I got a copper FW3C with working secodaries from JC,plus i have the normal CW version
The aux LED do ramp up/down, when put alongside my CW FW3 there isnt a lot of difference lumen wise but the tint is different due to LED swap
I’m not aware of any production clips. I’d be interested if anyone else knows of one.
I designed a clip and had it cut by a local waterjet company - unfortunately, I used the wrong material, it isn’t stiff enough. I’m not extremely happy with the shape either. I might remake one using stainless steel or a higher grade of titanium.
I have been using the clip from my Emisar D4 until I design a new version
