Well he sounds lovely, but on a more positive note he is unlikely to notice any serious flashlight action unless you have a Nitecore SRT7 with the police lights mode
I don't think it's legal in public places etc, but legal to use in your own home and legal to grow etc. Still get a wiff of it now and then on Friday evenings around town. Never liked the smell myself.
Do you know please,if the switch of this new light, is the same as the older mf01? I say this,because having the older light,I don’t like the switch which it has.
My MF01S voltage reading is considerably off when testing with the 3 click method and getting a read out, but the aux lights seem much closer to being accurate. If the aux lights are closer to being accurate, would that mean the LVP would step in at the right time or is the software using the other method to determine when the lvp should kick in?
I bought this,“BARSKA Accu Grip Handheld Tripod System”, from Amazon to use it with the MF01S,but the diameters are not the same.The light’s is bigger,while the MF01 has exactly the same diameter with the BARSKA,as it has a inner ss “bezel”.
Is it possible to fit the BARSKA to the MF01S?
Little late, but... The SW is using the same method as the 3 click reading, unfortunately. I modded Anduril to have a configuration UI to calibrate the voltage reading, so every Anduril light can be tweaked to be dead on or close. It's set in 0.05V increments.
Well, with my version, yes, because you can change it via the UI. But having the source code of standard Anduril and ability to build it, you can change the voltage "fudge factor" to correct it.
Just came back to ask you that very question in case I misunderstood! All clear now thanks. Looking forward if you ever release that new version with the tweaks as I never flashed a light before and need to learn how sooner or later.
