Just got the SF Skyline 1’s, thanks! The head is about 1/2in thick aluminum, and only light I’ve seen with a retaining ring for the glass lens
Interested in
Balder BD-1 XP-E R2 Cool White: $7
Balder BD-2 XM-L U2 Cool White: $10
Xeno F7 Cool White XM-L2 — $15
Xeno E03 Red Neutral White XM-L2 — $13
Xeno TW15 Diffuser Wand for Xeno E03 — $3
PM Sent.
About 7 or so lights added today! I’m about at the end of them, probably only have a few left.
I’ll take the bkfa01, and the lumintop Black worm
I’ll Take that other balder bd-2 too
I’ll take the Crelant 7G5CS XM-L U2
That one sold minutes ago. But I still have the 7G5CS with XM-L2 for $4 more.
- Anyone interested in a Crelant 7G9 head with XM-L NW. Not sure what happened to the body. But the head appears new and works on my power supply. Could be used for modding, or turned into a bike light or something? $5+ shipping
- Also have a Balder BD4 light engine, I believe the driver might be bad. But it includes the XM-L LED, driver, and whole aluminum part that surrounds the driver. Would be good for a modder that owns a Balder BD4. $2 + shipping
- Niwalker MiniMax15 Battery Tube in mint condition + flashlight handle + screws + Nylon case for $5 + shipping
- 3 broken Balder SE-1 — $3 each (includes pocket clips, cases, accessories)
Sure I’ll take that one!
I’ll take these (if available)
Just received my last order. F7 flashlight is in pristine shape. Everything I ordered was in pristine shape for that matter. Thanks for all these great deals on these extra high quality older model flashlights. Not as bright as current 2019 from other manufactures but built so much better.
Goodies arrived today. Everything’s perfect, thanks!
Btw, the hosts are hella nice! Amazed no one snatched ’em up long ago. Score!!
I got everything today. It is all great, and arrived very quickly. Thanks!
Saving a copy of the first post, going to reorganize it and delete the sold lights.
Hello BLF,
I’ve got some inventory I’d like to clear, so I’m discounting everything significantly. Everything is well below dealer cost and being sold at a loss.
The Niwalker, Keepower and Crelants for the most part only have 1 of each available. For the Xeno’s there are several of each available generally.
Everything listed is new unless otherwise stated. I will continue to add items so check back frequently.
I will do my best to test every light before shipping. Lights however are sold AS IS. Thank you!
Shipping over $75 is free and starts at $3 and will go up from there for US orders <$75.
Niwalker:
Niwalker Vostro BK-FA01 – XM-L2 (1200 lumens) — $35 SOLD
Niwalker Vostro BK-FA01S XP-L Hi (1300 lumens) — $45 SOLD
Niwalker Vostro BK-FA02S – XHP70 (4800 lumens) — $45 3 SOLD
Niwalker MiniMax MM18 2x MKR, 1x XM-L2 (5120 lumens) $50 (Test sample, lightly used) — $50 SOLD
Niwalker 55N3 XM-L U2 800 Lumens — $15 SOLD (Test sample, lightly used. Light only no box.)
Niwalker BK-FA01 — XM-L2 (1200 lumens) — $30 (Test sample, lightly used, includes box, has BKFA02 outer tube instead of BK-FA01 outer tube. Only difference is the markings). SOLD
Niwalker NWK600N1 XM-L U2 Cool White 700 lumens with magnetic ring — $14 (Test sample, lightly used. Light only no box.) SOLD
Shadow:
Shadow SL3 with 3x XM-L T6 Cool White. Gun Gray: $15 (Test sample, lightly used. Light only, no box.) SOLD
Keepower flashlights:
WD25 980 Lumens XM-L2 (includes case, USB charger, Keepower 18650 2600mAh protected cell) — $19 SOLD
WD1C 620 Lumens XM-L2 (includes case, USB charger, Keepower 700mAh 16340 protected cell) — $14 SOLD
WD2C 800 Lumens XM-L2 (includes case, USB charger, Keepower 18650 2600mAh protected cell) — $15 SOLD
Balder:
BD4 XM-L U2 Cool White: $16 SOLD
BD-1 XP-E R2 Cool White: $7 (Test sample, lightly used. Light only no box. Includes pocket clip) SOLD
SE-2 XM-L T6 Cool White: $6 (Test sample, lightly used. Light only no box. Includes pocket clip) SOLD
BD-2 XM-L U2 Cool White: $10 (Test sample, lightly used. Light only no box.) 2 SOLD
SE-1 XM-L T6 Cool White: $4 (Test sample, lightly used. Light only no box. Includes pocket clip) SOLD
TD0 Black XP-G2 R5 Cool White: $7 2 SOLD
TD0 Black XP-G2 R5 Cool White $6 (Test sample, lightly used. Light only no box.) 2 Available
Balder HD-1 XM-L U2: $4 (5 available. Please note that these units use a piston switch which had some reliability issues. These are new but are untested and sold AS IS. They are very nice looking lights! They can be used also as a twisty.)
-BD-1P XP-G2 R5: $10 1 SOLD 2 LEFT
N-light:
HB-65: 2x 18650 XM-L CW: $6 (Test sample, lightly used. Light only, no box.) SOLD
XT-50: 1x 18650 XM-L CW Zoom light: $4 (Test sample, lightly used. Light only, no box.) SOLD
Archon:
M20 Cree XP-G R5 6 mode magnetic ring 1x18650: $7 (Test sample, lightly used. Light only no box.) SOLD
M20XL Cree XM-L T6 800 Lumens 1x18650 6 mode magnetic ring: $8 (Test sample, lightly used. Light only no box.) SOLD
M10A Cree XP-G 1xAA + magnetic ring: $4 (Test sample, lightly used. Light only no box.) SOLD
M60XL Cree XM-L 3x18650 + magnetic ring: $10 (Test sample, lightly used. Light only no box.) SOLD
Solarforce:
Skyline 1 Cree XR-E Cool White: $6 (2 available) SOLD
Skyline II Cree XR-E Cool White: $6 (Test sample, lightly used. Light only no box.) SOLD
Lumentop:
P2C XP-G R4 NW — $9 (Test sample, lightly used. Light only, no box. Pocket clip included) SOLD
P1C Xp-G R5 CW — $9 (Test sample, lightly used. Light only, no box. Pocket clip included) SOLD
TD15 XP-G R5 CW — $15(Test sample, lightly used. Light only, no box. Pocket clip included)
Black Worm with XP-E R2 AAA0 — $5 SOLD
-L1C with XP-G R5 — $9 (New but will ship without packaging because packaging is damaged. Case included).
Crelant:
7G9 XM-L 1000 Lumens Cool White — $20 (Test sample, lightly used) SOLD
7G9 XM-L2 1020 Lumens — $25 SOLD
7G3CS XM-L2 — $12 (2 available) 2 SOLD
7G3CS XM-L Neutral White — $11 SOLD
7G3CS XM-L2 Cool White — $10 (Test sample, lightly used. Light only, no box) SOLD
7G3CS XM-L Neutral White — $9 (Test sample, lightly used. Light only, no box)
7G10 MTG-2 1860 lumens — $30 (Test sample, lightly used, Light only, no box) SOLD
7G5CS XM-L U2 1000 lumens — $20 (Test sample, lightly used, Light only, no box) SOLD
7G5CS XM-L2 Cool White — $24 (Test sample, lightly used, Light only, no box) SOLD
7G5 v2 XM-L U2 850 lumens — $15 (Test sample, lightly used, Light only, no box) SOLD
V9 XM-L U2 Cool White — $10 SOLD
-V31A XM-L U2 Cool White Gun Gray — $7 (Test sample, lightly used. Light only, no box)
Xeno: (several of each available)
ES1 Cool White XP-G2 Gun Gray HAIII with pocket clip — $10 Several available 1 SOLD
ES1 Neutral White XP-G2 Gun Gray HAIII with pocket clip — $11 Several available 2 SOLD
G5 Cool White XM-L2 — $29
G42 Cool White XM-L2 — $39
G42 Neutral White XM-L2 — $38 SOLD SOME LEFT
G10 Cool White XM-L2 — $28
G10 Neutral White XM-L2 — $28
G10v1 XP-G R5 Cool White — $14 (Test sample, lightly used, Light only no box) 1 SOLD 1 AVAILABLE!
F7 Cool White XM-L2 — $15 SOLD SOME LEFT
F7 Neutral White XM-L2 — $20 SOLD OUT
F7 Neutral White XP-G — $9 (Test sample, lightly used, Light only no box) SOLD
E03 Black Cool White XM-L2 — $12
E03 Black Warm White XM-L2 — $13
E03 Red Neutral White XM-L2 — $9 (Test sample, lightly used, Light only no box) SOLD
E03 Red Neutral White XM-L — $8 (Test sample, lightly used, Light only no box) SOLD
E03 Red Warm White XM-L2 — $13 3 SOLD.
E03 Blue Warm White XM-L2 — $13 SOLD OUT
E03 Blue Neutral White XM-L2 — $13 2 SOLD
E03 Blue Neutral White XM-L — $7 (Some signs of use/wear, overall good condition. Light only no box). SOLD
E03 Black Neutral White XM-L2 — $10 (Test sample, lightly used, Light only no box) SOLD
E03 Black Neutral White XM-L — $8 (Test sample, lightly used, Light only no box) SOLD
E03 Black Warm White XP-E — $6 (Test sample, lightly used, Light only no box) SOLD
E03 Black XP-G R5 Cool White — $7 (Test sample, lightly used, Light only no box)
E03 Blue Neutral White XM-L — $8 (Test sample, lightly used, Light only no box) SOLD
S3A Gun Gray with Pocket Clip XM-L2 Neutral White — $18
S3A Gun Gray with Pocket Clip XM-L Neutral White — $13
TWSE Diffuser Wand for Xeno ES1/ES2 — $2 SOLD
TW15 Diffuser Wand for Xeno E03 — $3 5 SOLD SOME LEFT
Redilast:
Redilast USB Mini Li-ion Charger 500mA with magnets and alligator clips: $5 2 SOLD. SOME LEFT
Redilast USB Mini Li-ion Charger 100mA with magnets and alligator clips: $6
Please post in the thread if you would like to reserve something, and then you have 24 hours to follow up with Paypal payment. And if there is anything else you are interested in that I carry from www.edcplus.com feel free to PM and let me know and maybe we can work out a deal. You can also email sales at edc plus * com
More lights added, some prices slashed, organized first post, also added a large lot of reflectors/optics for you modders out there!
I’ll take the shadow sl3. Pmed
I’ll take the 550N3 XM-L Cool White: $14
Sent a PM about buying one more E03 Black warm white flashlight. Thanks.
I would like to purchase a “E03 Black Cool White XM-L2 — $12”. Thanks.
Would like to buy the red E03, please; and the test black XP-G R5 E03.
Balder TD0 Black XP-G2 R5 added.
Please send PP/Total needed.
