【convoy】17mm SST40 driver with biscotti firmware and temperature protection will be available
2123 posts / 0 new
Simon Mao
Simon Mao's picture
Last seen: 3 days 13 hours ago
Mocarny wrote:
Simon, is it possible to make turbo mode access only after 2 click, from any position(on or off) without memorizing it? So it could be 0,1% – 1% – 10% – 40% and turbo after 2 click
yes ,and what driver model?
Satan@103TFS
Last seen: 13 min 13 sec ago
Simon when will the slightly bigger inner-diameter of your 21700 available ?
Mocarny
Mocarny's picture
Last seen: 4 hours 41 min ago
It could be in driver for SST40 and new 3*SST20
If turbo is only 1-2 min I can’t see point of memorizing it, and it would give more modes, 4 in loop and turbo when needed. Then it could be really “turbo”, not the highest mode
Yokiamy
Yokiamy's picture
Last seen: 5 hours 10 min ago
Simon, is there an easy method to change or disable the temperature regulation of the L21a SST40 driver (i have the version with 4 modes only) ?
Maybe by disassembling the temperature controller, or soldering a bypass resistor, or just bypassing it with a wire?
  BLF
Simon Mao
Simon Mao's picture
i’m not sure ,which mode do you need? i will leave you a message when it’s ready
Simon Mao
Simon Mao's picture
i have a driver sample ,0.1%-3%-30%,double click turbo
KevinZA1988
KevinZA1988's picture
Last seen: 55 sec ago
Simon, that mode spacing sounds good to me for the XHP35.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Mocarny
Mocarny's picture
There can be even 4 modes, but 3 are ok too. But 2 click turbo should be from any state, on or off, and long press for low is really great and handy, no need to cycle through all this bright levels. Good reading light is about 20-25 lm in warm white or NW, in CW little less (for me), so if it is an EDC light (in my opinion 3*sst20) there should be mode to have this 25 lm. 40 lm is too much for me, M3 has ~ 40 lm on 1% and it is too bright for reading, but good enough for walking. But M3 isn’t EDC reading light, I guess, so it is ok Silly
Will it be diffuser for 3*sst20?
Yokiamy
Yokiamy's picture
Simon, any ideas about this ?
  BLF
Simon Mao
Simon Mao's picture
uh ,it’s for reverse switch ,it only works when flashlight is on .
In the future, I can design a diffuser for 3*SST20 flashlight
Simon Mao
Simon Mao's picture
i didnt get reply from manufacturer,yet.
i will reply you later
Yokiamy
Yokiamy's picture
Thank you, looking forward to it !
  BLF
hodor
hodor's picture
Last seen: 3 hours 59 min ago
Anyone tried the SST40 in DA tint yet?
KevinZA1988
Still waiting for my 5000K DA from Simon and 5000K DD from Kaidomain to be delivered.
hodor
hodor's picture
Ooo will be interesting to see how those compare Innocent
KevinZA1988
Yeah I’m quietly optimistic… I hope that they will be a lot better than the “regular stuff” they have always sold in the past.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 2 hours 48 min ago
Wieselflinkpro wrote:
Is it possible, that you fit your 22mm XHP35 Boost-Driver to a 17mm driver board? That would be realy great.
Hi Simon, did you overread my question?
Simon Mao
Simon Mao's picture
Simon Mao
Simon Mao's picture
17mm is too small ,friend
Satan@103TFS
Simon is it possible to make XHP35 driver to run on 1S/2S battery and in 20 MM size?
VaKo
Last seen: 6 days 22 hours ago
Got an issue with my XHP35 driver in a L21A host with a freshly charged 40T – on 100% mode it will just flash and drop back down to 1% mode instantly. Also makes a high pitched whine sound that gets louder as you go to 10% and 40%.
Any ideas?
Simon Mao
Simon Mao's picture
Any ideas?
high resistance or low voltage,friend
Simon Mao
Simon Mao's picture
little small size 20mm
maybe can make xhp35 driver run on 2cells
Di_Joker
Di_Joker's picture
Last seen: 3 hours 33 min ago
Hi Simon.
Is it possible, that you fit your 22mm XHP Boost-Driver to a 20mm driver board?
Will the Convoy S3 (I like the design and the lack of pill) appear with thermal control and the choice of XML and SST emitters?
Sorry for my poor english.
KevinZA1988
Yeah I also love the S3. I have two custom built ones! I don’t even own an S2/S2+ because of the brass pill, and I won’t even buy the S21A because of that. Integrated shelf tube lights/hosts as well, please Simon?
Simon Mao
Simon Mao's picture
Di_Joker wrote:
Hi Simon. Is it possible, that you fit your 22mm XHP Boost-Driver to a 20mm driver board? Will the Convoy S3 (I like the design and the lack of pill) appear with thermal control and the choice of XML and SST emitters?
sorry ,only 22mm currently
sst40 and following driver can be installed in S3
17mm SST40 driver
Simon Mao
Simon Mao's picture
i will add a link in my store
hodor
hodor's picture
Any update on this beauty yet?
Simon Mao
Simon Mao's picture
available soon,about in 10 days
oweban
oweban's picture
Last seen: 10 hours 44 min ago
Exciting!
