I’m in.
I want a version of ASTROLUX MF01 Mini use 21700 battery.
I’m in! I would like to see Astrolux make a combination work light with a powerful flashlight attached. Nebo Tool makes some nice ones, but I think they need more power! Have a COB panel for flood and wide area attached to a flashlight with like 2500lm (xhp50.2?) But a nice beam pattern with moderate throw. Ron it off a single 26650, USB quick charge with ramping firmware.
Im in thanks!
I would like Astrolux make a nice AAA light that uses 10440 battery.
I’m in.
I would like that Astrolux makes a 21700 powered, 1,5 inch head, neutral white flashlight with high quality constant circuit driver and some great UI. Looking for running turbo mode almost until LVP kicks in.
I’m in , Would like to see 21700 small EDC FL.
I’m in
It would be nice if Astrolux could make a small EDC (AA) with a collar mode changer …great gift to elderly non flashaholics who may find it easy to use even with a bit of arthritis
Thanks Freeme and Astrolux
I’m in…happily try to destroy it underground on a few caving trips!!!
I’m in, I’d like to see a 2x26650 searchlight with a good combo of flood and throw.
I’m in
I would like an Astrolux to make a Ti pocket EDC light.
I’m in
I’d like astrolux to make an active cooling flashlight with more than 15.000lm and +1000m reach
I’m in. I would also like to see a LEP light that doesn’t cost an arm and a leg.
I’m in.
I’m in.
14500, anduril, side button, 3000K-4000K high CRI
I’m in!
21700, pocketable size, warmer tint perhaps?
I’m in. Thank you!
I would like Astrolux to make a 21700 light with a side switch, an XP-L HI emitter and a 40mm TIR.
Simple UI with 1 click ON/OF, ramping from moonlight to turbo, 2 click strobe, and 3 click batt.check.
Able to go max till the LVP kicks in. Inductive/magnetic type charger. NO USB plug and rubbers please.
Edit: and a slightly crenulated SS bezel. Sorry.
I’m in. straight or right-angled Compact 21700 single high CRI neutral white LED with a deep carry clip(please) that is not friction fit.
I´m in.
I would like to see a triple 21700, 1Lm start, ramping,with good balance throw & Flood.
I’m in
Astrolux have achieved thrower, flooder and EDC lights already so I would like ASTROLUX make headlamp with nice efficient moon mode running for months (like Zabralight) and keep low production cost for mass sales.
I’m in. An affordable LEP flashlight, or active cooling flashlight. Thanks!
I’m in.
21700, 4000k Tint high cri thrower.
