FW3A mod thread. Post yours!
That would of been plan “B”…If I would of screwed up…….
I got a copper FW3C with working secodaries from JC,plus i have the normal CW version
The aux LED do ramp up/down, when put alongside my CW FW3 there isnt a lot of difference lumen wise but the tint is different due to LED swap
You should ask for the firmware source code and see if he is willing to give it to you.
KB why don’t you do a GB with 18350 tubes? :wink:
I sent pic’s to NEAL…
And now we pray for them to listen our wishes :partying_face: :innocent:
Awesome I’ll hold thumbs
I’m not aware of any production clips. I’d be interested if anyone else knows of one.
I designed a clip and had it cut by a local waterjet company - unfortunately, I used the wrong material, it isn’t stiff enough. I’m not extremely happy with the shape either. I might remake one using stainless steel or a higher grade of titanium.
I have been using the clip from my Emisar D4 until I design a new version
I’d love an 18350 tube.
@doubleu That clip looks pretty good!
That looks great!! I’d be down to buy one from you if you decide to have another go at it. I’ve got a polished titanium FW3 hopefully on the way soon that will be perfect for it.
That is the one real thing missing on the FW3A, a decent deep carry clip. The stock clip, both V1 and V2 seem to be plenty strong. They do get caught on a seat belt from time to time and I have not killed either one.
I only hope to add to this thread, not take away from the custom diffusers.
Both the Felix AOD-S and NiteCore NDF25 diffusers fit very, very snugly on the FW3A. They are very useful with candle mode. Of the two, I prefer the AOD-S, as it can be used either tail standing or diffuser down.
Thanks for the info. I like the look of the AOD-S.
The AOD-S does not look to bad. I am not a fan of rigid diffusers, they do not pocket well. I really hope to find one of the smallish silicone ones that will fit, none of my selection will fit. The ideal one, for me, would be similar to the one that fits the TiTool. I may try to make a form and form one up, not sure how well that will go.
Copper version with optic and glass removed on turbo.
CCT: 4556K
DUV: –0.0096
CRI: 95.2
Gray aluminum with optic and glass removed on turbo.
CCT: 4404K
DUV: –0.0109
CRI: 95.7
MF01S with optic and glass removed on turbo
CCT: 4355K
DUV: –0.0096
I have a feeling both of these are FD2 tint bin because from what TA said, there was an extremely limited number of FA3 tint bin on the market in the range of 1,000 pieces only. Fireflies said Luminus recently wanted to make some more FA3 tint bins so there should be more.
Like the style of the Fenix diffusor, looked it up and ordered it for 4EUR locally, thanks for that!
I have yet to find a decent 1” silicone diffuser. That’s what I would prefer also. The Fenix will be for my nightstand.
Finally got around to modifying Anduril and flashing it with an update that has manual memory and removing a couple modes I never use like some blinkies and muggle mode.
Main alteration which was fairly simple: set it up so that when locked out, instead of going to the second ramp’s floor on the double click it goes to what’s set for manual memory. Much nicer to use for my case, I always accidentally activate it so it sits in lockout most of the time.
This just means I now have a preset double-click momentary in lockout for when I need light for a couple seconds, but don’t have to raise either ramp’s floor. Only drawback is manual memory needs to be activated in order for said function to work.
Ooop’s I did it again :person_facepalming:
Baby Ti….
Were you playing around with dad’s shrink ray again? :laughing: :smiley: :+1:
