Hi Simon.
Is it possible, that you fit your 22mm XHP Boost-Driver to a 20mm driver board?
Will the Convoy S3 (I like the design and the lack of pill) appear with thermal control and the choice of XML and SST emitters?
Yeah I also love the S3. I have two custom built ones! I don’t even own an S2/S2+ because of the brass pill, and I won’t even buy the S21A because of that. Integrated shelf tube lights/hosts as well, please Simon?
i will add a link in my store
available soon,about in 10 days
Exciting!
[quote=Simon Mao]
:partying_face:
Indeed! Does she have a name yet?
Are there more detailed specs on that triple? I’m interested.
Seems like it’s a non standard size, so optics can’t be swapped, 7135x14 running crescendo unless that’s changed. Simon was trying to run it on an attiny13 but it requires an attiny25 to work properly, I guess he got that sorted out. 3x SST-20. Simon probably still has the common binned greenish tinted ones since the good tinted SSTs are apparently hard to get unless you are Lumintop.
I’m curious to see the beam profile with that reflector. It would make it interesting to swap emitters…
As a separate host as well I hope.
LH351D dogfarts
convoy S12
My Convoy S21A with SST-40 5000K arrived today, so I went white wall hunting.
I assume it is this emitter: SST40-40-WDS-F50 FLUX: N5 Color: DA Voltage: VJ CRI: 70
At 100% does not look green even next to my E07 219B sw45k. Very likely below BBL.
At 30% it still does not look green even next to my E07 219B sw45k. Probably below BBL.
At 0.1% and 3% it looks green/yellow next to my E07 219B sw45k. Probably above BBL.
I did not do any measurements though. Spill is noticeably cooler than hotspot and corona.
I like rosy tint, and I can instantly see green/yellow tint on some of my SST-20 4000K lights. I don’t see any green tint at 30% and 100%, it looks “pure white” on a white wall.
Sounds great, potentially amazing with a dedome/slice?
Thank you for the feedback. Looking forward mine! It’s probably the best tint sst-40 I’ve heard about. When used outside that little bit of green/yellow at low currents should be acceptabl….
However, I doubt slicing the dome would improve things. All the 6500K SST-40 dedomes/sliced domes I’ve tried all went horribly green/yellow at lower currents. I’m not gonna try it again, unless someone has the balls to slice their 5000K ones…
Now that 5000K is actually readily available (unlike when the FT03 came out) I might be persuaded to give it a go… just gotta get a nice sharp blade and some washers.
Weird one. Couldn’t see a problem. Took it apart, put it back together, worked fine.
