Looking at that TaoBao page:
It’s significantly larger than D4S / E07. This gives it some throw, despite thick bezel. Would be interesting with 7x White Flat 2 mm². Or 1 mm² so it can sustain the output a bit longer.
Heavy as a brick.
Brand: MATEMINCO
Material: Aluminum alloy
made in China
Color classification: black SST20 6500K black SST20 5000K black SST20 4000K aluminum color SST20 6500K aluminum color SST20 5000K aluminum color SST20 4000K sand color SST20 6500K sand color SST20 5000K sand color SST20 4000K gun gray SST20 6500K gun gray SST20 5000K gun gray SST20 4000K olive green SST20 6500K Olive Green SST20 5000K Olive Green SST20 4000K Copper SST20 When shooting Remarks Color Temperature Copper XPL HI Shooting Remarks Color Temperature Brass SST20 Shooting Remarks Color Temperature Brass XPL HI Shooting Remarks Color Temperature Yellow Copper Limited Edition SST20 Shooting Remarks Color Temperature Yellow Copper Limited Edition XPL HI When shooting, note color temperature powder purple orange gold SST20 when shooting color temperature powder purple orange gold XPL HI shot when the note color gentle mask and flashlight together
Weight: 168G
Charging mode: Multi-function charging
Maximum range: 500m and above
Continuous lighting time: 4 hours and above
Price tag: 368
Is it waterproof: Yes
Whether it can be adjusted: No
Rechargeable: Rechargeable
Time to market: Summer of 2019
Item No.: MT07
Maximum brightness (maximum luminous flux): 350 lumens and above
Charging time: 4-6H
Use time: 100,000 hours
Gear position: stepless dimming
Length: 111*43*44MM
Lamp and accessory type: LED
Battery specifications: 18650
I always thought they would use the same optic as the E07 but those TIR cups are alot bigger than the E07. It’s a much more efficient use of space. The throw should be amazing on this thing. Probably even more so than the D4S.
