Click happy muggles! Gifted my son in law FW3A. My mistake.
Have had to reset the ramp ceiling a couple times for him and his itchy switch fingers.
He gave me the light to check and it was acting really strange in the ramp with different intensity levels.
I couldn’t get into any adjustment settings and really was thinking light had a real problem. Nope muggle had put it in muggle mode on his own.
I did not recognize muggle mode because I think he managed to change the levels in muggle also. I haven’t actually checked that yet.
After I exited muggle I did have to reset the ramp ceilings again though.
I may have to take his away. Funny my daughter never has a problem with hers. And I still love my 2.
Yeah, it’s too easy to get into configuration modes accidentally, in Anduril. IMO, they should be tricky to get into; but once you’re in, easy to configure. Okay, we’ll never get “easy to configure” in a complex UI. But, at least, it should be difficult to accidentally configure.
IIRC, a reset feature was recently added. It was difficult to do accidentally, because I think you had to hold the button when inserting a battery. Something like that. I think all the configuration menus should only be activated that way.
Ah, for the days when such lights connected by USB would allow for programmatic access, and a backup of settings. This way if the config ever got screwed up, you reset and simply reload your backup.
I want to purchase a few extra FW3A drivers because I mod and break things often. I have FW3A comming soon in the mail so I am unfamiliar with how it works.
I am unable to find where to purchase the drivers directly.
Also, are there other drivers that are compatible? The drivers I have are only the click ON/OFF tail switches.
I dont know what type of switch the FW3A uses. Is it always connected with momentary clicking, or direct ON/OFF, or something else entirely.
You would have to go to Neal or Lumintop directly for this. The driver is eswitch (“direct on/off” = mechanical switch) and an unusual size and placement of the eswitch area since it is not connected via a wire like most eswitch drivers.
I believe it does now, but the original FW3A’s don’t have it. I’m not sure if the ones shipping now have the updated firmware with the reset function. Probably, but get confirmation before ordering if it’s important to you.
Yes, Illumn has been checking and calibrating each light. This is an awesome and helpful thing for them to do, but it’d be really nice if the factory would do it instead.
In any case, that makes Illumn the best place to buy from, if you’re in their shipping area.
Thank you for great info. Is anyone able to help which emitters should I pick. What are the pro and cons between XP-L HI 3D , SST 20, Nichia 219c for this beast?
Would like to have high lumen, high cri (will this matter?), good flood with enough throw, and keep it low temperature. But I know I cannot have it all.
I don’t have any experience other than XP-G2 S3 with my Mecarmy SGN5.
What is the good balance for overall EDC around the house and night street walk?
Yes, it’s more neutral white, but a very “clean” tint without being clinical. I find it very powerful and considering the turbo output plus form factor, it performs very well.
I suspect that illumn.com is NOT calibrating the copper version which is vacumn sealed to prevent tarnishing. (There was someone in another thread reporting an electrical contact problem with their new copper FW3 they purchased from illumn. com. Had illumn calibrated that light, I am sure that they would have noticed the problem and fixed it.) But if you are ordering the FW3A, illumn.com is the place to go in the USA. Perhaps, even with the copper version, you should go there, because their custumer service is great should you ever have a problem.
I agree . I was the one with the problem, and it got resolved in a couple of hours.
They are in the USA and ship quickly.
I am certain the copper is not calibrated by them because it is indeed vacuum sealed.
In fact, the clip corroded the copper a bit on the tube. I cleaned it up with a salt/vinegar combo, and a little toothpaste!
I have not calibrated the heat, but it gets so hot so fast you can not keep it above 800 lumens for more than a few seconds.
