interested
Hey freeme, don’t suppose you have a Convoy M21A to compare it to? I could see those as being quite similar size wise.
Interested in C8 21700 Sand model/ SST40. Thank you.
Interested in C8 with XHP 50.2 3V
Interested
Interested!
Kindly indicate your preferred setup, with reflector and emitter choices info.
Please take note that there might be some issue with XHP50.2 setup. We are still checking with the manufacturer.
Can I find out approximate prices?
Apart …
SST-40 ?
XHP50.2 ?
Before seller could work out the retail price, he has to decide which models to stock up first.
I’d like it with a SMO reflector and CW LED. Light in black preferably…
Interested: Model: C8 21700
Nice flashlight :)
Of course I've had to get one and that's how I ended up here. SS bezel, desert tan finish, XHP35 HI, 21700.. Now that's a winner in my calendar :) And ofc, SMO reflector, no question.
On the AE store there's also more options to choose from - XP-L HI, XM-L2, SST-40 and XHP35 HI. No XHP50.2 though, which is interesting.. Myself, I've just got into liking the XP-G2's and XP-E2's lately - quite nice emitters Cree was making in the past I'd dare say. And I'm not even sure if I've got the good versions of them or just the worse "updated" / newer ones..
Now, to top it all up - March C8F 21700 Anduril, am I right ?
Cheers! :)
Interested in C8 21700 Sand XHP 35HI. Thank you
Kind of dilemma here which emitter to choose. With that size format, I believe both SST40 and XHP35 will have almost identical output, being driven not as hard as they possibly could be. I dont care for the extra throw of XHP35, as the reflector of this model is rather small anyway. What matters to me is the driver and ability to run turbo and high mode with almost empty battery. Here I would expect that XHP35 having a boost driver would be able to do so. Can someone confirm?
hi freeme, interested in C8 21700 xhp35 please!
Package includes MARCH C8, lanyard, spare lens, thread lubricant, spare tail switch, 4* o-rings, and 2*18650-to-21700 silicone converter.
Can you please get more info on the drivers of SST40 and XHP35 versions? Would like to know if the XHP35 can use high/turbo mode with almost empty battery, as it is a boost driver. Also any chance of getting these in neutral white?
Interested in the C8 21700 sand, SST-40, OP reflector.
Will this be a Banggood deal?
Interesed C8 XHP 35 HI (21700)
