Sorry but bistro is way more convenient, you can go up and down whenever you want = at any mode.
Here you are stuck in an ascending and descending sequence. Is there a time out for the descending sequence ? If you turn off the flashlight while in the descending sequence and turn it on later, are you still in the descending sequence ?
Yes, I agree with you on that, Bistro is more configurable in that option (go up and down at any regular mode mode)!
About timing, there is none for the sequence to change, it is completely memorized. It is like stepless dimming flashlights, if you were going up/down before OFF, it will maintain the same direction.
The “good” thing here is that we can always start from the bottom > up, from the top > down, or from the middle (in this case it will be up or down according to the last direction used)!
I find it versatile due to this, despite I also know that most of the times we are used to have a pre-determined sequence (normally bottom-up) for our use.
But, in any case, and as I mentioned before, the best option would be to have the possibility to ascend/descend in modes at will, like some ramping UIs are using currently!
OK MascaratumB, I better understand how it works now.
It might be more convenient than how I first pictured out to myself with this UI from OFF but at the exception of the sinusoidal cycling when ON. I think that 1 H (press and hold) to go UP and 1 C + 1 H to go DOWN would be less confusing than trying to remember if you are or were in the ascending or descending part of the cycling sequence.
Though, the behaviour of 1C and 1H being different in group mode A and in group mode B will not work with me.
I get what you say!
Please note that from OFF, with Group Mode B, you have something more or less similar to what you mention but with double click + hold.
Meaning: OFF > Double Click + Hold = Turbo and starts descending in the mode sequence (T1 > H1 > H2 > M1 > L1)
In this group mode you also have the possibility to go from the lowest mode up to the top (0.5s press from OFF for Low and then click & hold to change modes - ascending -, like in an Olight). Single clicks are for ON/OFF .
The Group Mode B is “simpler” than the A one! Only thing I wish it had, instead of “Double click to SOS” was “double click to Turbo”, that can only be accessed from OFF in this group mode.
Yes, it does behave differently, but, for me, it will be a matter of choice of what Group Mode will I prefer to use and then stick to it!
B is simpler than A, and the light can then be used with or without memory, “single” mode (single click ON/OFF - this is what lacks in many other lights in this category :zipper_mouth_face: ) .
If I need a lower low, I will opt for A, but then he UI is more intrincate…
Is the UI similar to the BLF A6?
MascaratumB, You've definitely got your format of review fine tuned! Comprehensive, thorough, abundantly illustrative! In short, thank you for the review!
No LightObsession! The reference above to bistro UI was only a small comparison, but the UI on these lights is not similar!
This is BLF A6! Please go to this thread for more information: Flashlight User Interface Cheatsheets
And this is Skihunt M150 UI, from the user Manual:
Here is the description I’ve made:
And here are 2 videos demonstrating the User Interface of this flashlight!
Group Mode A
Group Mode B + Unlock+ Location beacon
Thank you Nachtfeuerzeug I do the best I can and that I know honestly!
Some things are still missing (night beamshots and some “tests”) but I’ve been busy with other stuff! As soon as I can I will post those!
Thanks for reading!!
So much wasted potential in this light : /
Is that because of the UI and the emitter, or other aspects?
I guess there is no single light that will “fill the measures” for all of us!
Look at the FW3A, the D4 and many other lights beinge released! They all “lack” something and they are superb lights ‘per se’…
Only thing we can hope is for Skilhunt - as other manufacturers - to listen to the community to improve their lights…
- It could be made smaller, including the diameter, by not having magnetic charging. Plus I’m pretty sure they price they ad for it is higher than a decent quality lightweight charger.
- XP-L2 CW and OP is obviously a bad choice, XM-L2/XP-L HI 5D/3A or Luxeon V would be a much better choice, especially with a TIR or diffused lens.
- It’s not modable I geuss (not 100% sure)
- SOS is pretty dam useless
I tried to talk them into using blue locklite for the threads of the head in their Skilhunt H03, which is easily removable my a modder and impossible by a random, instead of red loclite which is a PITA to remove, but I didn’t feel they did understand the issue I was referring to.
BTW great review
Sorry for the late reply Ryzbor!
And thanks for detailing your points!
Hum, comparing it with the other side switch AAs, it is pretty small! The Manker E11 is smaller, but it doesn’t have magnetic tail. Sofirn SP10A/B is already a small light but this one is still smaller than it! About the diameter, of course, without the magnetic charger it will take more space! Unless it it was charged through the tail, Olight style, I guess this is the “possible size” for a light like this ! Untill a smaller one appears with the same specs
Agree! NW or WW would be tremendous! After I take my night beamshots, I will put a Luxeon V2 5000K to see how it looks like and will report
The diffusing can be made through some plastic sheet like DC-fix or others! I will try that when I mod it
The LED is “changeable”. The driver, not so much!
I will probably agree. Even if it can be handy, it would not be needed. And even if I’m not a strobe fan, I’d rather have the strobe or flash only!
I saw their answer on the Skilhunt thread and I do understand their point about this. Skilhunt is not necessarily Sofirn, Convoy or Jaxman. They have a different range of products and a different relationship with the market, meaning probably many customers that are not “enthusiasts”. Therefore, they probably prefer to give them a “reliable” and verified product instead of something that can be modded/damaged more easily! It would be like saying to Olight “don’t glue your heads”…
At least here, on this M150, one can change the LED and the reflector/lens…
Thank you
Adding some more reviews here and on the web:
*Narmattaru - Review: Skilhunt M150
*Lumeniac (Narmattaru) - 🔦 Обзор карманного фонарика Skilhunt M150 | 14500 Li-Ion, 750 люмен - YouTube
*Review or How it works - Review Skilhunt M150 — pocket EDC flashlight for 14 500/AA - YouTube
*zeroair - Skilhunt M150 Flashlight Review - ZeroAir Reviews
Looks pretty good. For some reason I thought it was bigger - maybe I misread the spec sheet. Relatively speaking the size looks fine for 14500.
For me the CW is a deal-breaker. And the sinewave UI is a dealbreaker. Both are easily fixed so maybe I revisit it in the future to check if Skilhunt make a revision.
So, today I am adding some (delayed) beamshots, showing how the Skilhunt M150 behaves outdoor and indoor too!
I opted to show mostly the different levels (from the lowest level to the highest) instead of showing the 5 preset levels on the group mode 2.
I also compared it with some of my other AA/14500 flashlights.
I only used 14500 cells in these beamshots. With AA alkalines or Ni-MH rechargeable cells, the outputs will be different, namely giving lower distance range on the higher output levels.
Enjoy
First the evolution through the 8 levels: indoor vs outdoor!!
Tint Comparison:
Left to Right
Wuben E05 (Luxeon V) > Sofirn SP10A (XP-G2) > Skilhunt M150 (XP-L) > Manker E11 (XP-L) > Lumintop Tool AA V2.0 (XP-L)
Wuben E05 > Skilhunt M150 > Lumintop Tool AA V2.0 /////// Sofirn SP10A > Skilhunt M150 > Manker E11
Skilhunt M150 vs Wuben E05 > Manker E11 > Lumintop Tool AA V2.0 > Sofirn SP10A
And some beauty photos! And others
Thanx for lot of pics!
The light itself is great, the UI is acceptable, but the tint….is uglyyyy.
Thats nice!
I bought few XPLs and XML2s in 3000K and itstalled them in some of my lights. And immediately became the big fan of the warm tint. So the cold white tint of the M150 is like nightmare to me…
So, after some delay, I finally got to mod the Skilhunt M150.
I took out the Cool White XP-L HD emitter and put a Luxeon V2 5000K bought a while ago from Led4Power.
You’ll see the difference below
BTW, I also measured the PCB. I was a bit disappointed, as I thought it was thicker. NO! Also, it didn’t have any kind of thermal paste below! Ok that this is not a hot rod, but still, it should have some. So, so besides replacing the LED, I also put some thermal paste!
BEFORE [XP-L HD Cool White] >>>> AFTER Luxeon V2 5000K
Comparisons with Luxeon V 4000K (under a TIR, on the right)
Luxeon V2 5000K vs Luxeon V 4000K (with SMO reflector)
CONCLUSIONs:
This is my first light with a Luxeon V2 5000K!
And I love it!
And it is so much better than a CW LED in this flashlight!
And if it is not completely perfect, it is much more pleasant than a XP-L HD CW emitter!
Skilhunt, if you are reading this, please consider offering this light with Neutral White emitter!!!
The lumens may be lower, but it will be much better and more pleasant!!!
Also, altough I am getting used to this UI, consider the suggestions given in the Poll you organized!
BTW, the mod is not difficult! You just need to reflow an LED on the PCB so that it works well and solder it again!
Thank you for a very elaborate review.
There is one remaining question. IMHO bezels are made to protect and serve.
That nice blue bezel, is it made of (stainless?) steel, or just colored aluminum.
